Full Metal Platinum 1.5 - Radio problem
Old 6th Feb 2007, 5:01 am
Default Full Metal Platinum 1.5 - Radio problem
Just received this player but the radio has an annoying clicking sound. I thought it was interference from the screen but it continues when the screen turns off. Reception is otherwise good but the constant tapping sound makes it unusable.
Anyone else got one of these players without this problem?
Firmware details:
Core: ACT 9x_0.48
Date: 2006-09-12
FW: SRX-1.5C-003
Date: 2006-10-20
Old 7th Feb 2007, 2:25 am
I have the same model, identical firmware and the same annoying clicking noises.. the radio is rubbish.
But I don't listen to the radio much anyway.. so i'm not going to miss it.
[hr:43af44b395]
Old 7th Feb 2007, 5:55 am
Que Que is offline
I have that when changing volume (icon blinks on screen and it seems to relate to that). Reception/sound output itself is clear. Only when you go to the menu while using the radio, the distortion gets so bad you want to rip the phones from your ears. The same when recording from radio, the result is awful. Got 2 replacements, but they suffer the same.
Old 7th Feb 2007, 1:11 pm
Default Re: Full Metal Platinum 1.5 - Radio problem
I have the same problem. But not in all stations. Itīs rare.
Old 8th Feb 2007, 12:49 am
There really isin't any solution to the clicking problem in the FM radio. It is a result of poor filtering of unwanted noises.
No firmware fix can do anything about it, it is a total hardware problem.
Old 14th Feb 2007, 6:52 am
Will send it back to Uxcell for a replacement. But from your replies it's likely that this will also have the same problem.
Thanks for your input.
Old 5th Mar 2007, 3:46 am
Replacement works perfectly.
Many thanks Uxcell!
2gb Full metal platinum 1.8 fraimond Support and How To 0 30th Apr 2007 11:35 am
Full Metal Platinum 1.8 Deckar General Discussion - Uxcell.com 15 27th Feb 2007 6:28 am
Full Metal Platinum 1.8 in Red Deckar General Discussion - Uxcell.com 1 15th Feb 2007 8:39 pm
Full Metal Platinum 1.5 vietnamesetan General Discussion - Uxcell.com 1 10th Feb 2007 9:42 pm
Full Metal Platinum 1.8 2GB... Yoshi General Discussion - Uxcell.com 10 6th Feb 2007 9:19 am
