-   -   Teclast C260 (http://mympx.org/forum/general-discussion/36602-teclast-c260.html)
Pocket_Nano 10th Feb 2007 9:13 pm
Teclast C260
I have just received a shipment of 50 Teclast C260's and every single one of them is set to Chinese in the language option. This is my first shipment of these players and do not have any set to English to refer to. So my question would be if anyone here either has a Teclast C260 or if anyone can tell me how to change the language to English it would be greatly appreciated. Thanks!.
Pocket_Nano
tadad1 10th Feb 2007 10:59 pm
Pocket_Nano, Download the C260 English Manual Here:
http://uploaded.to/?id=mhsrcv
At a quick glance it appears that if you enter the Settings menu, select the second entry, then first entry and then third entry should be English (maybe)
Check out Teclasters.com as well that is where I downloaded the manual.
Pocket_Nano 11th Feb 2007 10:05 am
Thanks!. Very much appreciated!.
reefskinner 11th Feb 2007 11:09 am
Re: Teclast C260
50 of them.....wow! How much will you be selling them for? I would be interested in one. What size?
Shawn
Pocket_Nano 13th Feb 2007 10:30 am
The English user manual came in real handy Tadad1 thanks for that. Them steps might of worked for the old firmware. But since they updated it now it's 5>>1>>3 for English. This might help others to know to try both suggestions to get it set to English depending on their firmware version.
How to set your Teclast C260 to English:
1) in main menu find the settings icon which is a picture of a spanner
2) in this menu theres 7 options, go down to the 5th option and select that
3) in this menu there is 3 options, select the 1st option
4) then in this menu select the 3rd option
You can now read your Teclast C260 in English!. :lol:
Pocket-Nano
Pocket_Nano 13th Feb 2007 10:37 am
Re: Teclast C260
Shawn
I don't know for sure what they will sell for yet. I have 50 1GB Teclast C260's. But of course they also have the Micro SD Card slot which can hold a 1GB Card giving you now a 2GB Player. So far they look sweet!. Very nice Players, they remind me of the Meizu M6.
Pocket-Nano
