Inside the box
Old 15th Feb 2007, 8:02 am
If that thing replaces the USB cable, I'd strongly advise not using it. It will be so rigid that sooner or later, you are bound to screw-up the small usb socket in your player.
I'm guessing it'll have a female usb socket at one end, so then you can use a regular usb to usb cable.
Old 15th Feb 2007, 8:12 am
i got the usb cable with the mini little one , oh also i forgot to put in my charge , its a proepr uk usb charger.
need fw ,info inside Edgaras Dead Players 16 25th Sep 2007 10:00 pm
A picture of a 4GB chip inside a player ashley_rb General Discussion 2 26th Apr 2007 8:20 am
HELP, i need firmware for TPOD NEO 1 Go (photo inside) fitigre38 Dead Players 0 22nd Dec 2006 7:51 am
Dead player all specification inside... Bronco Dead Players 1 13th Oct 2006 7:05 pm
[NEED FW] NO Nano-like player!! Look pic inside, thanks!!! Remoz Dead Players 0 1st Aug 2006 1:26 pm
