LCD SWAP
Old 19th Feb 2007, 8:27 pm
Default LCD SWAP
Hello everyone ive got an inspire nova mp4, has a 1.5 inch screen and i was wonderin if there is a way to swap up to a different one, ive got a spare 2.5 inch all alone in a dark corner being regected, Has any one tryed such a procedure or know a site?? thanx
Old 19th Feb 2007, 8:31 pm
MPx-a-lolics Anonymous
i am sure someone will help you out with that but how come your total posts says a huge number 16777215 and you have become a MPX-a-lolics when you have joined only on 17 Feb
Old 19th Feb 2007, 9:31 pm
Default Re: LCD SWAP
say wha????????? im a noob to this forum type lay out so i didint know what that meant but WOA somthins wrong :? i don wanna get in trouble PLEASE HELP ME
Old 19th Feb 2007, 9:37 pm
wow deepakr.. u r very good in making those signature...
Brilliant
waiting for exam results.
Old 19th Feb 2007, 9:42 pm
Total posts: 16777215....????????????????????????
wow.........how can u reach that number....???joined 16 feb 2007????very very weird...impossible
Old 19th Feb 2007, 11:04 pm
lol RicanJoe you wont get in any trouble. dont worry. admin will correct it
gaboon thanks for appreciating my sigs
Old 20th Feb 2007, 2:01 pm
Anyway, regarding the topic of LCD swapping, it may be a matter of simply connecting it, but LCDs require drivers that are usually specific to that model of LCD.
Can you provide me with some model/serial numbers and I'll check into it for you...
Friendly Beatings Available - Enquire Within
Old 20th Feb 2007, 2:06 pm
um u cant the connecter of the 2.5 and 1.5 fit each other. the 2.5 is like .5inch bigger so its not going to work and also the nova is a cstn so u have to find the correct screen for it
Old 22nd Feb 2007, 3:56 am
RicanJoe , as zetski210 mentioned, the larger 2.5" screen would need a different screen driver. This would be embedded within the firmware. You'll need to extract the firmware and modify the screen driver module to support the 2.5".
The pin-outs for both screens should be about the same, but the location of the pins might not. And besides, a 1.5" player might not have sufficient space for a 2.5" screen.
Old 22nd Feb 2007, 4:09 am
the space is the real problem..and the processor mey not be capable of scanning a frame that is as large as a 2.5 inch screen..jitter of display may happen..
Rockchip Player Battery Swap knob Support and How To 2 7th Aug 2007 12:18 am
