mp4 plug charger
I just ordered from uxcell and I live in Canada and they gave me a north american charger but it doesn't have the holes, is it still safe to use?
Re: mp4 plug charger
Are you talking about the holes in the plug blade?? Then yes, its fine to use. I live in Canada and haven't had (electrical) problems with any of these usb chipod chargers. I think its more European countries that have to worry about that.
ohhh, at first i thought that since it didnt have the holes I was worried that it wasn't safe to use but according to you its safe :D thanks.
vietnamesetan , i still don't recommend people using the AC adaptor. It likes to pop and cause damage to players. So use the computer's USB to charge as far as possible. Only use the AC adaptor is a last resort.
Also, ensure than you do not overcharge your player using the adaptor. It takes about 10 times faster to charge using the AC adaptor than computer USB. |
| All times are GMT -7. The time now is 10:18 am. |
