can i replace flash memory
Old 2nd Mar 2007, 8:12 am
Default can i replace flash memory
Alotta you know that my 2 gigabyte nano clone doesn't work because the internal switch is broken. I would like to buy a new player with like 128 megabytes or something, and switch the flash with my samsung k9lag0....... 2gb flash. is that possible? will i break the player if i just rip out the memory?
Old 2nd Mar 2007, 4:32 pm
pmilladcs , you'll need to de-solder the chip out. Ripping the chip out would damage it.
You'll also need to consider both chips need to have the same exact pinouts.
There is a guide on S1mp3 wiki here http://wiki.s1mp3.org/index.php/How_..._a_memory_chip
Old 3rd Mar 2007, 12:21 am
ill buy your non-working player from you , how much?
Flash Memory usa6116 Dead Players 1 16th Aug 2007 11:19 pm
How to replace memory chip? andy_267 Support and How To 1 15th Feb 2007 9:00 am
Where and how to get more FLASH MEMORY green8 General Discussion 1 21st Nov 2006 4:28 pm
formating flash memory fritsieh Dead Players 13 3rd Aug 2006 2:10 pm
adding more memory on your mp4 via flash memory, possible? jb_jonas Support and How To 1 18th May 2006 1:25 am
