Meizu M6 vs Telcast T29, which is better?
The Meizu M6 and Telcast T29. Both seem to have similar prices and features. Both offer 4GB now, and 8GB soon. Is one better than the other?
I like the Meizu but the Telcast is a great player. Just go for the look you like best .
I think that T29 has better sound due the dual chips. T29 is also very stylish and has a own look, unlike meizu that has copied iPodīs style. T29 is also smaller, wich makes it a bit more poratable. But Meizu has a bit larger screen. Both of these players are great. I will get a meizu m6 later though. I might would pick the t29 cuz its smaller. Now you decide! :P
If they cost the same, go for the Meizu.
The T29 does not have better sound than the M6, it has a better signal to noise ratio which in essence means (for regular users like us) that when using high-end sensitive headphones, we will hear more white noise on the Meizu. The firmware and sound is better on the Meizu. So if they cost the same, go for Meizu. |
wow! I just won a 4gb meizu m6 on eBay for only $83 plus $15 shipping. I'm estatic; I heard these go for at LEAST $140 on houseofdap. If meizus are as good as people say they are, I'm going to be in heaven. Goodbye nanoclones, and hello meizu! Can't wait until it arrives.
...Relating the topic of discussion, as you can see I prefer the meizu to the telecast, even though I don't have either. It's just the meizu has a smoother look, bigger screen, and tactile scrollpad. It's just my opinion though and by no means am I knocking the telecast. |
Re: Meizu M6 vs Telcast T29, which is better?
Congrats, you won a Meizu clone :) lol... If it is a real meizu, then that would rock!
I think that Teclast looks a bit smoother. And wow, they didn't copy apple like all chinese companies do lol. Meh, both of these players are great. :P |
I'll update when it arrives |
omg....that's cheap... :)
Wow nice deal princessanne1026!
Another point that i feel the T29 is better, would be the controls. The M6 uses some touch sensitive navigation, whilst T29 uses a joystick button. When I'm on the bus or walking, it is easy to just slip my hand into my pocket to flick the button to the next song or increase/decrease the volume. Not very sure how easy the M6 would navigate, you might need to take the player out to navigate, unless you are very very familiar with the player itself. |
While I only used the Teclast T29 for a week I found the joystick control clunky and cumbersome especially when trying to press the joystick straight down, the slightest bit of lateral movement activated the directional controls. The Meizu touch pad however I find quite accurate and easy to navigate.
The Teclast 2inch LCD has a anti-glare coating which is a little pointless as it is behind the glossy face plate which is reflective. The anti-glare just gives the LCD a grainy muted quality. The Meizu 2.4inch LCD renders a much cleaner sharper image quality. With the latest firmware the Meizu includes album art support and 10 bar EQ visualization. The MP3 decoder has been optimised to improve performance and the player now delivers 24-28 hours continuous play depending on EQ, Bass-Treble Boost and 3D Spatializer sound settings. Firmware updates for the Meizu are released more regularly with new features and bug fixes. OTG file transfer is currently under development which will enable file transfer without PC connection using the Meizu external power pack. There is also an excellent theming community for thr Meizu at meizume.com which offers over 50 truly excellent customized themes for the M6. Make Mine a MEIZU. |
| All times are GMT -7. The time now is 8:33 am. |
