Full firmware or BIN 9.0.50
I was wondering if anyone has or knows the location of a FULL firmware file for a Lisong MP3 player made by Wilson Co. Ltd using v 9.0.50?
I have been following these excellent threads for a couple of days and have managed to format (fat not fat32) my "4Gb" player which now has the presumably un-hacked 2Gb. this acts as a flash disc and stores files. The player itself only has a blue screen. I am presuming it now needs a firmware installation and have tried a range of suitable alternatives from this site using the new 4.05 MP3 utilities. I am only left with a full version of firmware to try. It is a 1.5 inch with radio, black nano like player from ebay. Purchased last month. Thanks for any suggestions. |
MP4Crusher , at the moment, the firmware extractor S1fwx only supports upto v9.0.43, so others with a working v9.0.50 are unable to dump their firmwares for you to try.
If you had tried all the v9.0.xx series firmwares in the downloads section and still unable to recover your player, try contacting your seller and see if they have the firmware to send to you. Also, search the CD that came with your player, sometimes it is inside and should be in .fw or .bin format. |
| All times are GMT -7. The time now is 8:31 am. |
