:: Questions about 2 (2GB;2") Players ::
Old 27th Mar 2007, 9:46 am
Default :: Questions about 2 (2GB;2") Players ::
Hello,
i just want to know if someone has one of the following players and can answer me some questions
1: 2GB, 2" TFT Display, Chrome design, SD Card slot, Built-in battery :
- Whats about the lifetime of the Battery & can i replace it when its fucked up?
- How loud is the speaker?
2: 2GB, 2" TFT Display, Changeable Nokia Battery:
I don't know which one i should buy, the first has SD slot and the second a changeable battery what would you do ? and which one is better quality?
thanks, macko187
Old 27th Mar 2007, 10:22 am
The 2nd One is a glacier - Buy from UXCELL -To get one , They are more reliable , The first one is most likley a hacked player - Im guessing this because Action chip players , Rearly
(Yes i know they can support more)
Only support 2GB Genrally.
I wouldnt buy either of those unless you know 100% they arnt hacked , If they arnt go for the glacier - Nokia changable battery = A+++
Old 27th Mar 2007, 10:31 am
the first is a 2 gig player... they written 4GB because you can put 2GB SD-Card in... if its hacked i send it back but i dont think so this guy has about 2.000 100% ratings in ebay.. is the glacier speaker quality good ?
Old 27th Mar 2007, 10:46 am
you are 100% sure that its not hacked - go for glacier i recon , changable battery , speakers are crap but good enough still for you to use
Old 27th Mar 2007, 1:57 pm
macko187 - you're in luck; I happen to own both players. I don't know what seller you got the first picture from, but like lite said, I would be wary of the player being hacked (though, come to think of it, I've never heard of a hacked rockchip player). Anyway, I would say definitely the top one is better. Even though the player in the second picture has the benefits of the removeable battery and everything, it has a slower processor than the first one, meaning that it responds more slowly. Also, there have been a number of problems reported with the second player.
Old 28th Mar 2007, 3:09 am
Default Re: :: Questions about 2 (2GB;2") Players ::
ok thanks for the help i ordered the 1st now
one question how good is the speaker quality because i mostly hear music loud is it good or not so ? in compare with actual mobile phones ?
greets, macko187
Old 28th Mar 2007, 7:31 am
macko187 , definitely you can't expect the same quality as mobile phone speakers. The speakers used in these players are usually cheap speaker units, so when you turn the volume up, don't be surprised if the sound gets distorted.
SOLUTION - Fixing "Disk Error" in hacked AK2025 players TonyB Support and How To 36 10th Jun 2010 3:36 pm
eBay seller "lovehuimp3mp4" sells hacked players dittoLIVE Bad sellers/Blacklist 0 10th Mar 2009 9:53 pm
A couple Questions on Full Metal Platinum 1.8" Tim9294 General Discussion - Uxcell.com 6 13th Feb 2007 4:44 pm
Basic questions about MPx player, "firmware", &quo Nano_Clone Support and How To 2 24th Dec 2006 8:10 am
