MP4 palyer upgrade
Old 27th Mar 2007, 11:21 pm
Default MP4 palyer upgrade
Hi,
I am bhima, i have purchased a chineese sony MP4 player, it says it can play AMV/MP4 but i am unable to play MP4 on it and as well the video for AMV seems to be jerky. I would like to know how to i play some good videos without any jerks. i have tried virtual dub also as per this forum, but was unsuccessful. And also i would like to know if i can install a mp4 or mtv player in this firmware, i mean here the player.
Details of my player are,
mp3 player
QY035E-5K
CM60026-w
2006/12/26
ACT_V3.5.37
1.8''
filename = 'dump.bin'
filetype = afi
md5 = FE1195A0EBF6192A71C9AD3E7930854F
file id = 'AFI
vendor id = 0x6977
product id = 0x6552
version = 3.5.37
date = 00/00/0000
| BRECF644.BIN | | 16kb | | F644 | | B | | 55F928DC |
| FWIMAGE.FW | | 7.47mb | |
| | I | | 145E5970 |
| SYSINFO.BIN | | 192bytes | |
| | | | CC3FDDEA |
filetype = fw
md5 = D999A62DDA1213C3FD2E335FDA511127
---[ info:fw ]-----------------------------------------------------------------
file id = 0x0FF0AA55
vendor id = 0x10D6
product id = 0x1100
version = 3.5.37
date = 12/16/2005
info = 'SDK-ITEM/ACTIONSGongee.ZH'
device name = 'S1 Mp3 Player'
usb attr = 'GENERIC'
usb ident = 'USB DISK DEVICE'
usb rev = '1.00'
rtc rate = 0x3B6
display contrast = 6
light time = 0
standby time = 30
sleep time = 0
language = simple chinese
replay mode = 0x00
online mode = 0x00
battery type = 3.6V li-polymer
radio/fm support = no
Old 28th Mar 2007, 12:17 am
bhima_t
These cheap chinese ipod clones are incapable of playing mp4 files and mtv conversion just creates such large files that are really a waste of space.
Although your firmware is modifyable, there isn't an upgrade that will allow you to play mp4.
My recommendation would be to just leave it as it is with it's original firmware intact. There are a number of different versions of AMV Converter in the download section. One of those should give you 'watchable' movies. Perhaps version 3.57 or 3.70
One of the key things about using VirtualDub is you need patience to experiment with a variety of settings until you get the result you desire.
...Or you could always get yourself a new player
[hr:43af44b395]
Old 28th Mar 2007, 2:20 am
Thanks a lot buddy. I was about to experiment the upgrade of firmwares. But i stoped now after seeing ur response. i am also trying on virtual dub. i found a solution to my question. the solution is in vitrual dub convert the frame rate to 12 fps and so some normal compression using any compression method and then allow that avi to amv comvert for high fps and mode 0. this will work perfect.
can u get a touch screen theme for this palyer, im new Lemonfuzzy Mods and Themes 3 11th Oct 2008 1:32 pm
mp4 palyer 150$ robis General Discussion 3 10th May 2008 10:48 pm
MP4 Palyer Cyrilic ID3TAGs? qwerik Support and How To 1 14th Mar 2008 9:31 am
i can't upgrade PLEASE HELP gemelo71 Dead Players 1 23rd Jan 2008 3:36 am
How upgrade to 3.5.37 of 3.5.35? spidermaxcl Support and How To 2 27th Jul 2006 1:54 am
