Perfect PAL video conversion for Rockchip players
Old 30th Mar 2007, 9:21 am
Default Perfect PAL video conversion for Rockchip players
I bought a Rockchip player on Ebay (UK) and though very impressed with the player, I was dissappointed by the jerky videos produced by the AVConverter software. I tried AVIConverter from this site and found no improvement. However, after digging around, I've modified the configuration file and can now produce XVID AVI files from PAL originals that run perfectly on this player. The modifications also allow a few more options in quality and aspect ratio. If anyone else is interested, I'll see if I can get the configuration file in the downloads area (any advice on how I go about doing this?).
Old 30th Mar 2007, 9:51 pm
Default Re: Perfect PAL video conversion for Rockchip players
Grindathotte,
That would be great if you can share your findings with others.
You can upload it to our site by clicking on [Downloads] then [Uploads by Members]. Then click on the Click the image to open in full size. button.
Hope that helps and thanks for sharing.
Old 1st Apr 2007, 1:43 am
Thanks, I've uploaded the file RockchipPal.zip, which contains the modified converter.ini file and Readme.html. This needs to be used in conjuction with AVIConverter, also in the downloads section.
Old 8th Apr 2007, 3:20 pm
wow! i serached for this alot of time. thenks man!
Free Video converter for Rockchip players Abdul-Nimer Video related 15 14th May 2008 2:51 pm
My first greeting:the perfect solution of AVI conversion... Qinan Video related 6 11th Feb 2007 7:37 pm
What resolution should I use for my video conversion? adamlg9291 Video related 6 26th Dec 2006 9:40 pm
AMV Video Conversion to 128 x 160 crazygazza Video related 1 1st Oct 2006 6:19 am
