need firmware ACT2097_S75 ver 9.0.50
Old 2nd Apr 2007, 12:29 pm
mikeg
Guest
Posts: n/a
Default need firmware ACT2097_S75 ver 9.0.50
does anyone have firmware for a 4gb mp4 with a 2.0 screen
firmware info
2006/10/30
9.0.50
2006/06/12
This is a tronfy.com WT5 model and can be seen on that website
Old 3rd Apr 2007, 8:42 am
mikeg , are you having any problems with your player? If not, i'll suggest not doing anything to the firmware as it would likely brick it with a wrong firmware update.
Old 7th Apr 2007, 3:19 am
Default Re: need firmware ACT2097_S75 ver 9.0.50
mikeg,
send me your mail address,
by the way, it is not a 4GB it must be 2GB.
if your player is running, do not upgrade firmware!!!
Old 27th Apr 2007, 1:31 pm
Hello!
I got problem when trying to upgrade firmware for my mp4 player.
It's a fake Nano with no brand name on its
It got 2Gb Samsung memory
FW Version is: act2097_s75 9.0.50
Can ya help me out?
I used Mp3 Player Tool 4.19 and 4.00 but it won't recognize my mp4
Thanks for your time
This is my email: hiddendragoon@gmail.com
Old 27th Apr 2007, 1:47 pm
And this is it!
Old 27th Apr 2007, 8:40 pm
fantastic , do you mean that after you upgraded your firmware, MP3 Utilities can no longer detect the player?
If so, you'll need to perform the Dead Player Recovery guide here http://www.mympxplayer.org/dead-play...ide-vt567.html
Old 27th Apr 2007, 11:00 pm
Thank you so much! I made it work again and fine
I dont know how to express my gratitude
Old 27th Apr 2007, 11:05 pm
Bust the problem here is: my MP4 did have FM, but after I recovery fw, FM lost
Do you know which fw that has MUSIC / MOVIE / VOICE / GAME / FM / SETUP / TEXT ?
Old 28th Apr 2007, 12:15 am
fantastic , you can try to use the Waterlily software, but i'm not sure if it supports v9.0.50 firmwares.
Download here http://www.mympxplayer.org/waterlily...-mb-df256.html
Next, install and open the firmware file that was able to recover your player.
If Waterlily supports your version, you should be able to load the firmware properly, and select the FM function, and as well the default language.
If Waterlily does not support your version, then there is nothing you can do about it.
[solved] Looking for fware: ACT2097_S75 - 2006/09/06 9.0.48 xxMDxx Support and How To 4 23rd Jan 2009 12:05 pm
Need Firmware - MP4 Player with 4GB 2'' ACT2097_S75 9.0.48 AnTo Dead Players 21 21st May 2008 9:35 am
Dead player, looking for firmware ACT2097_S75 ver 9.0.48 chinjay68 Dead Players 14 27th Jul 2007 12:26 am
