Help: Need to find out more info on this player.
Old 3rd Apr 2007, 5:01 am
Default Help: Need to find out more info on this player.
****************Feature****************
~Huge Display Area 2.2" 260,000 TFT LCD
~mini SD Extension Slot
~Replaceable Battery (Extra Battery is avaiable for purchasing)
~Dual Work allowance - You can listen to the music when you are reading the novel.
~Dual Earphone-Plugs - Share the music or movie with your friend
~Directly Read Avi format (Needn't convert the movies into AMV format)
~Built in Speaker
*****Specification*****
~ Support Mp3,WMA,WAV music format
~ Support MPEG-4(avi) video frequency format reception
~ FM is saving 40 broadcasting stations also
~ Support JPEG format picture browse
~ inside place microphone, super long playing recording
~ Economy energy establish, the bright degree can regulate freely, shutting down automatically
~ Various sound effect, circulation can be provided as choice
~ Support a multinational writing
~ Support win98 SE/Me Win2000,the system of Win Xp,Mac
~ USB2.0 The high speed transferring
~ Support E-Book
~ Built in Game
-------------------------------------------in pack--
- 2GB 2.2" Mp4 Player
- English Manual
- 1 x Earphone
- USB Cable
- Install CD
- 1 x Replaceable Battery
l
i'm looking to buy this player but looking for info about firmware or company its made from...just so i know what i'm bying is decent.
need info about this player waratte General Discussion 0 3rd Jan 2010 10:10 pm
Please help me getting some info about my MP4-player! Gore Support and How To 7 22nd Jan 2009 11:09 am
[HELP]How to find firmware or chipset info Jiizake Support and How To 13 15th Jan 2009 9:36 am
how to get player info forceofhuha Support and How To 1 19th Mar 2007 8:03 am
more info on this player? backudog Support and How To 8 2nd Nov 2006 10:08 pm
