Problems with 2GB Glacier...
Old 11th Apr 2007, 6:50 am
Default Problems with 2GB Glacier...
Hi!
I bought a 2GB (of course advertised as a 4GB model) Glacier a few months back from eBay (seller coolstuff_onlinestore , nowadays known as i-proshop.)
All was fine until today when the battery ran out while I was at work. I let the device be by itself for a few hours until out of curiosity I turned it on to see if it had any power left. Bad idea. I was greeted with a "DISK ERROR"-message. Found out just recently that the data was somehow all messed up and Windows claimed it wasn't formatted at all.
But the real problem of the story happened just 5 minutes ago. I had the player charging with the wall adapter, and decided to put my cellphone charger & phone to the adjacent slot. I heard a loud pop and smelled some burnt equipment. Sure enough, the adapter pretty much blew up. Marvelous.
So, I have two separate questions:
1.) does the 2GB Glacier always mess up / wipe all the content when the battery runs out?
2.) is there any other way to charge the player than with the wall adapter? I'd rather not start fighting with the seller to get a new adapter, so if there's a way to charge it with the computer, for example, I'd be happy to know.
Cheers!
Old 11th Apr 2007, 8:13 am
I don't know if it works for the glacier, but with my Ipod Nano clone, I using the USB wire to charge it !
PSP : 3.03 OE-C
MS : 1GB + 2GB + 4GB
XMB : Encore 4 + Hykypoo''''s Icons
Old 11th Apr 2007, 10:20 am
Default Re: Problems with 2GB Glacier...
hi oddjobs Firmwire update And charge adaptor press two menu(m)
charge MP4 player oke ?
Enjoy
Glacier Repair Toolkit - How to fix glacier player alex2pb Support and How To 14 16th Dec 2008 1:51 am
Some Glacier Problems and fixes. larrylwill General Discussion - Uxcell.com 4 9th Apr 2007 2:45 pm
Glacier Camaro General Discussion - Uxcell.com 7 7th Mar 2007 1:49 am
What to do first?New Glacier. Camaro General Discussion - Uxcell.com 8 23rd Feb 2007 3:56 am
More USB problems with Glacier michiganjfrog General Discussion - Uxcell.com 5 21st Jan 2007 2:35 pm
