Rockship firmware, how to extract from this player
Old 7th May 2007, 6:51 am
Default Rockship firmware, how to extract from this player
IMG OF PLAYER AND MENU
http://img132.imagevenue.com/img.php..._122_450lo.jpg
My player desc.
Mp4 With 2 MP Camera & Flash, SD-Slot ..
2.4”,QVGA,262K color displayer, with expanding interface.
512mb SAMSUNG flash memory.
Camera with 2 million pels, flashlight, supporting capture, video recorder and audio recorder.
Support video formats of AVI/ASF/WMV/MP4/MTV/3GP/MOV/MPG/DAT/VOB.
Support MP3/MIDI/WMA/WAV/AAC audio format, support synchronous lyrics, 5 kinds of EQ modes and support file management similar with that of winamp’s.
Support e-book reading, multi-encoding format, e-book mark and reading setting function.
Support JPG/GIF/BMP/PNG image format and image setting function.
Fine quality digital FM radio, Support automatic and manual search function with Europe and Japan Modes.
Support built-in multi-games: Explode Pigboat, Throw egg, Bet21, Color block, Russian diamonds and Bead.
Support NandFlash/SD card.
Support language of English and Chinese.
Support play list manage.
Support Clock function, fixed time power off and power on.
Support firmware update.
Specifications
[hr:251abab191]
Displayer: 240*320*QVGA
Driver: HX8310
PC connect: USB2.0 (full speed)
Memory: Norflash/Nandflash/SD card
Camera: 2 million pels
Battery: lithium battery, max paly time: 10 hours
Record: sample rete:8khz; format: WMA(32kbps), ACT(8bps)
Video: format: AVI; SNR: earphone:>=90db, speaker:>=88db; frame rate:>=25fps; frequency:240*320
Speaker output: 620mw, >=88db
Earphone output: 75mw+75mw
Mp3 bite rate: 16kbps, 320kbps
Frequency response: 20Hz-20khz
Distortion rate: <=0.05%
FM: 76mhz,90mhz/87.5mhz,108mhz; 20 stations; 75mw+75mw; 50db
Game: Built-in funny games
Format: ASF, MTV, AVI, VOB, DAT, MPG, 3GP
Temperature: -5-40
Language: English and Chinese
Support system: Window98/SE/ME/2k/XP
[hr:251abab191]
[hr:251abab191]
I Suggest this is a Rockship, and how do i extract the firmware
Or How to update my player ?
I whant to update because i have found a look alike player it looks exactly like mine but on "that" player you can play NES emulated games
i suppose the firmware is "hidden" in "hidden "partition
FAT16 , VBR/ Volume boot record , boot sector ect.
please help me
Old 18th May 2007, 1:48 pm
Default Re: Rockship firmware, how to extract from this player
The firmware is not hidden in the flash in Rockchip players. Assuming the websites I've been to are correct, the main firmware is stored on the Rockchip itself.
If it's possible to write the firmware through the USB port, it should be possible to read it, but no one has reverse engineered the software yet.
Old 18th May 2007, 4:48 pm
Look at the 31 firmwares using the editor that is also downloaded from this link.
http://www.mympxplayer.org/all-about...light=rockchip
Dave
16GB Touchscreen Rockship player is dead buscopan Dead Players 12 8th Dec 2009 5:21 pm
Plz help to Recover ROCKSHIP 2808 player athlant Dead Players 0 14th Oct 2009 8:18 am
PRoblem with mp5 player rockship phandil Support and How To 6 5th Aug 2008 10:00 am
Torn btwn a glacier and a rockship player soanime General Discussion - Uxcell.com 1 16th Apr 2007 9:40 pm
Mp4 player cannot extract firmware katuga118 Mods and Themes 7 19th Jan 2007 11:07 am
