-   -   isn't it possible to have clickweel in chinapods? (http://mympx.org/forum/general-discussion/38020-isnt-possible-have-clickweel-chinapods.html)
hyeclass 17th May 2007 2:17 am
hi guys, i have a question, isn't it possible to put a clickweel in the chinapods , is it so difficult?and i hate the slow working of my ipod nano 2nd generation fake 2gb model. Is it possible? :)
_Odyssey 17th May 2007 4:27 am
Re: isn't it possible to have clickweel in chinapods?
hyeclass, not really unless it contained the control circuitry. But then, chipods processors are so slow it wouldn't be able to handle it. If you want a clickwheel, just buy an iPod :lol:
lite 17th May 2007 10:11 am
Yeh , if the clickweel is a smart thing and all it does it says tactile commnds to an ipod when it converts your movments all it needs is a little re-wiring and your done , also itd beed a power supply if its that smart , But i douht apple would make their click weels "Smart" so probly not
The slowned is due to the processor speed , Not the buttons
