Help 2in amv
Old 17th Jul 2007, 5:14 pm
Default Help 2in amv
Can any one give me a walk through on how to get full resolution on my 2in glacier
Old 19th Jul 2007, 12:18 am
Default Re: Help 2in amv
The screen resolution is 128X96. Make sure you use that resolution when converting video files. When you load the file into the converter, click on the file name and then on the little gear icon that links to the settings. Pick the correct resolution. If it doesn't list 128X96 you don't have the correct version of the program.
