Need some advice for my next player.
Old 22nd Jul 2007, 12:03 pm
Yeh , there was a update in the 2.000.2.3 firmware which clocked the processor properly to put it up to 36 hours ,
Sorry if i sounded insulting , I didnt mean to.
Old 22nd Jul 2007, 12:07 pm
Don't worry about it. I didn't take it that way. 8) I am actually glad you posted that because it makes me love my Meizu even more!
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
Old 22nd Jul 2007, 4:56 pm
Thanks for all the excellent points and opinions.
Battery life is not much of a concern with me.
I would choose a smaller player without a replaceable battery.
What would you guys say separates the meizu M6 (I have never had my hands on one) from the other higher quality rockchip mp4s(such as Optimus x).
Is it just the ease/ speed of library navigation? the fact that firmware is mod-able?
I would really like an external speaker.
I'm truly torn. But I think shopping for one is half the fun.
Thanks again everyone.
Old 22nd Jul 2007, 6:23 pm
Kope, I can't really compare it to other Rockchips like the Optimus since I don't have one. I can say that hands down it surpasses the Chipod. The sound quality is incredible and the video is amazing compared to my 4gb Chipod with a 1.5 inch screen.
File browsing is fast. The touch controls take a little getting used to, but once you do, navigating the menu is a breeze. You can listen to music while browsing the files.
If you haven't already, check my previous post where I included the You Tube link. Razzer gives an informative review on the Optimus and has a thread about it posted in the MP4 player reviews. 8)
8)
Old 24th Jul 2007, 5:53 pm
well Ive' managed to convince one of my friends that he just has to have one.
So now I'll just steer him to one of the rockchip players I was contemplating and wait till he gets his so I can try it out.
Thanks for all the input.
Maybe I should just wait for the M8 phone.
  #16 (permalink)
Old 25th Jul 2007, 3:23 am
Yeh im gonna get the M8 when it comes out , Looks brilliant...
If you wanna get a cheap rockchip player try out this...
http://mympxplayer.org/heya-guys-che...er-vt6534.html
Click on the omega link
The Omega , May only be 1gb but you can upgrade it via the micro SD slot... It has the same size screen as a meizu and touch buttons and its cheaper and a FMP from uxcell (It plays ,avi files and has a built in radio all the basics youd exspect.
Some advice on this player hora123 General Discussion 13 23rd Dec 2007 11:20 pm
Looking for some advice on which player to buy Newfie_Chick General Discussion 6 25th Nov 2007 7:22 pm
i need some advice for my dead player geni Dead Players 0 12th Nov 2006 10:15 pm
advice on getting an mp4 player General Discussion 2 19th Jul 2006 4:27 am
Advice: compression on mp4/mp3 player ljlayos General Discussion 3 10th Jul 2006 7:59 pm
