replace battery
Old 5th Aug 2007, 8:13 am
Default Re: replace battery
I see that the battery that you all have bought have a white, red and black wires. On our MP4 players, there are only red and black wires. What did you do with the white wire on your new battery? Did you just cut the connector off and solder the red and black wire to the chipod and leave out the white wire?
Old 5th Aug 2007, 9:03 am
On the ipod mini I had it was Black, Grey and White.
So I just put a voltmeter on them to check.
Grey and White were both positive at 3.8v and Black was negative.
So I just cut the Grey one off and soldered in the White and Black wires.
Its always safer to check with a meter before you solder them in.
Old 7th Aug 2007, 3:11 am
Hi
I have a fake ipod with a battery that is 4cm x 2cm x 4mm deep. I can't seem to find any battery that are the same size or smaller. Can anyone please help me? also how did you manage to find a similar sized battery.
Old 7th Aug 2007, 3:44 am
Ipod shuffle battery should fit:-
http://cgi.ebay.co.uk/ipod-shuffle-a...QQcmdZViewItem
http://cgi.ebay.co.uk/APPLE-iPod-SHU...QQcmdZViewItem
It's 30 x 19 x 4mm at 300mAh
I just searched "Ipod Batttery" on EBay.
Old 7th Aug 2007, 3:54 am
hmm only 300mAH? my current fake ipod battery is 260mAH, so theres not much more :\ Are there any bigger capacity ones?
Thanks for your help
  #16 (permalink)
Old 7th Aug 2007, 4:53 am
for a battery that size, you are not likely to find much more.. Sorry.
My two iPods are jealous of my two MPx players.
  #17 (permalink)
Old 7th Aug 2007, 5:24 am
Here is a E Bay link for replacement battery for the Chinese Ipod Nano Fake.
These batteries are rated at 250 Milliamps
http://cgi.ebay.co.uk/Replacement-Ba...QQcmdZViewItem
And another link!
I have order myself a replacement battery from the link directly above from here, price to the UK £2.49 which don't seem too bad from this E Bay seller actionace007 however it seems he has something to do with Uxcell.com
:idea: I Can''''t wait to get my teeth into the mother of all mp3 players. THE M8 :P
  #18 (permalink)
Old 7th Aug 2007, 5:43 am
i am able to find batterys that dont have wires coming out from the battery that fit my size, they are 750mAH. The only problem is that they have no wires coming out of them. Instead they have a positve and negative touchpad on the battery itself. I was wondering if its safe to solder wires onto the positve and negative point on the battery then solder the wires onto my fake ipod?
  #19 (permalink)
Old 7th Aug 2007, 6:08 am
Post a link here for the battery you mention please?
And Yes I can't see why you can't solder that battery you mention, if it has no wires.
But check with a meter first before you connect
  #20 (permalink)
Old 7th Aug 2007, 6:48 am
Batteries like these:
[web:24ad69c63f]http://cgi.ebay.com.au/Casio-NP-20-Battery-Pack-3-6v-500mAh-Li-ion-FAST-DEL_W0QQitemZ120148122492QQihZ002QQcategoryZ64347Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem[/web:24ad69c63f]
which dont have wires, but have positive negative terminals on them. Is it safe to solder wires onto the terminals on the battery? or will it kill the battery? Also will a 3.6volt battery work with our fake ipods?
How to replace or fix a battery dimples78 Support and How To 3 5th Mar 2008 1:53 am
How do you replace the battery? mpxguy Support and How To 1 29th Aug 2007 8:28 pm
Battery replace koschris Mods and Themes 1 25th Feb 2007 11:08 pm
replace battery wlazio2000 General Discussion 2 30th Dec 2006 10:50 pm
replace battery!!. nieuwe accu!!. Da_fixer General Discussion 0 3rd Sep 2006 1:24 pm
