replace battery
  #21 (permalink)
Old 7th Aug 2007, 2:06 pm
The battery you show looks a bit lumpy in size, as it's for a camera.
Voltage wise it would seem ok for me, but others may not agree.
If you were to go for one of these batteries are you sure it will fit in your player? If so then just tin the contacts and your wires with solder, but don't hold the soldering iron on the battery contacts for too long or you may damage the battery and melt the plastic also.
But as mentioned before do use a muti meter to check the correct polarity first after soldering the wires on to prevent damage to your player
:idea: I Can''''t wait to get my teeth into the mother of all mp3 players. THE M8 :P
  #22 (permalink)
Old 14th Aug 2007, 5:11 am
Default Re: replace battery
Hi,
I am wanting to replace the battery in a chipod. The existing battery is an HT Li_on 042030 180mAh (l) battery. It is 30mm X 20mm X 3mm. I'd be grateful if somebody would confirm the size of the ipod shuffle battery and whether all ipod shuffle batteries are the same size. It would be great if somebody could let me know the part number of the battery that I need. Ideally I would like to get a battery with more capacity, perhaps 300mAh?
Chris.
  #23 (permalink)
Old 14th Aug 2007, 5:54 am
If you look back to an earlier post in this thread I put up a link to a UK ebay supplier for Ipod shuffle batteries at 300mAh.
  #24 (permalink)
Old 14th Aug 2007, 6:32 am
Not exactly a replacement battery, but for those that are unsure about their soldering ability, something like this (2400Mah Li-Ion rechargeable USB charger @ $13.83 delivered) is a good deal to extend battery life when away from an USB port. It's quite small and doesn't weigh all that much, but can obviously be somewhat impractical to lug around unless you're carrying a bag for work/school anyway.
  #25 (permalink)
So the Shuffle replacement batteries should fit in Nano clones? If so i think i'll order one too.
  #26 (permalink)
Old 14th Aug 2007, 7:23 am
Thanks Knob.
Battery ordered.
Chris.
  #27 (permalink)
Old 14th Aug 2007, 8:43 am
i've checked the shuffle batteries sometime ago and they should fit quite well with a little bit of extra space in your nano clones.
However, these shuffle batteries are usually about 250mAh, which is about the same as the stock battery of the nano clones. So don't really expect much increase in playback time, unless you're swapping a damaged battery.
  #28 (permalink)
Old 14th Aug 2007, 8:47 am
Thanks. My chipod battery is supposed to be 180mAh, but it will only hold charge sufficient to play the radio for about 10 minutes. The vendor offered to exchange the Chipod, but it would cost more to post it back to China than buy a 300mAh replacement, so I ordered up a new battery instead, which has cost me about a fiver.
Cheers,
Chris.
  #29 (permalink)
Old 14th Aug 2007, 9:21 am
My Nano clone's stock battery is 180mAh and lasts for about 3.5 hours. If basic math applies in batteries too, then a 250mAh battery would last me for almost 5 hours.
I think it's worth the five bucks.
  #30 (permalink)
Old 14th Aug 2007, 9:30 am
Unique,
The replacement batteries seem to be 300mAh and are sometimes better quality than the ones you get with the player so you may even be able to double your playing time!
How to replace or fix a battery dimples78 Support and How To 3 5th Mar 2008 1:53 am
How do you replace the battery? mpxguy Support and How To 1 29th Aug 2007 8:28 pm
Battery replace koschris Mods and Themes 1 25th Feb 2007 11:08 pm
replace battery wlazio2000 General Discussion 2 30th Dec 2006 10:50 pm
replace battery!!. nieuwe accu!!. Da_fixer General Discussion 0 3rd Sep 2006 1:24 pm
