Mutant MP3 Car Radio!
I was wondering if any members do own a Mutant MT1105USB MP3 Car Radio?
I have a small problem with mine, it works fine in most respects, apart from, now it now turns off when the ignition is turned off with a loud audio clunk, which it has never done before up until now. It is most annoying as I have to keep the ignition turned on if I want to use the Radio. Before this strange fault developed I would normally turn the ignition on to use the radio, swicth the radio on and if I turned the ignition off the radio would remain on. Anyone got any ideas on this? |
Re: Mutant MP3 Car Radio!
check the connection for the permanant live
| All times are GMT -7. The time now is 1:23 am. |
