Meizu M6 Crystal Case
Old 25th Aug 2007, 1:55 pm
Default Meizu M6 Crystal Case
Hey guys, does anyone know where to get this from...or any crystal case that has that hole in the back to place that kind of belt clip?
[img=left:47eeaf3af9]http://www.meizu.com/bbs/UploadFile/2006-7/2006712174279587.jpg[/img:47eeaf3af9]
Old 25th Aug 2007, 7:14 pm
popupstoppa , you could get them from houseofdap.com for about $9 each. http://www.houseofdap.com/index.php?...iewCat&catId=5
There are a couple of colours there, so take your pick.
Old 25th Aug 2007, 7:22 pm
Default Re: Meizu M6 Crystal Case
The house of dap site does sell the crystal cases, however not the same kind as the picture. I already have a belt clip, and would like to keep using it (I clip it on my shorts when I work out at the gym). Do you know if their belt clips can clip onto shorts? The velcro straps never fit around my arms.
Old 25th Aug 2007, 7:39 pm
popupstoppa , i'm not sure what you are referring to, but the ones sold by house of dap comes with a belt clip which should be able to clip onto a pocket or shorts.
Old 25th Aug 2007, 7:41 pm
Sounds good. Thanks for the info.
Onda 858 case Everso General Discussion 2 2nd Nov 2008 5:59 am
Crystal Ball tr171 General Discussion 0 13th Nov 2007 11:43 pm
Has anyone tried a Meizu M6 case on a Glacier? dsrome General Discussion 0 6th Sep 2007 7:26 pm
is there a case available for any of these players? callwing Miscellaneous 21 19th Aug 2007 3:36 am
Silicon case Applemac General Discussion 4 26th Jul 2006 1:55 am
