General questions about Nano clones
Old 8th Sep 2007, 11:55 am
I have a similar player.
If you haven't had a chance to play with one of these, there are a couple small details you might want to know.
You cannot browse through your files while the music is still playing.
Had I known this I would not have bought it. I find it so annoying to have to stop listening to look for the next song I want to hear.
Also when you are looking through files the player is rather slow.
If your getting just a one gig, and plan to use it on shuffle mostly then this player would be fine for you.
Another thing I would add is the risk vs. reward for flashing the firmware is just not there. There is really no reason to ever flash this kind of firmware. It seems that no new features are added and the liklihood that your player will be bricked is high.
Old 9th Sep 2007, 12:50 am
What version of firmware are you use? This is not a problem in the newer versions.
Old 9th Sep 2007, 7:33 am
Just my luck.
I believe it is 9.0.50.
I've had it for about 4 months.
Have you seen these ipod nano 3rd Gen Clones Bull Durham Miscellaneous 3 15th Jun 2009 10:58 am
Very New to MP4 and Nano Clones, need help sinanalo Support and How To 0 26th Mar 2008 6:29 pm
Ipod Nano 3rd Generation General Information Kildar General Discussion 8 23rd Mar 2008 5:28 am
3rd generation Nano Clones are out !!! Hotboxx General Discussion 25 24th Dec 2007 3:36 am
8GB Nano Clones for sale! delacerda Bad sellers/Blacklist 6 6th Mar 2007 9:11 am
