2.4" player from Ebuyer. Is it .AVI? is it .AMV??
Old 25th Sep 2007, 4:23 am
Default 2.4" player from Ebuyer. Is it .AVI? is it .AMV??
Hi,
I have stumbled across this thing from Ebuyer:
http://www.ebuyer.com/UK/product/126083
Initially, I passed over it as I thought it was an AMV player. However, having read the specs, and the reviews, it seems it might actually be an AVI format player. Does anyone here have this player?? The price of this model ( and the 2GB one) is tempting - but not if it's AMV !! :?
Cheers.
iixorbiusii.
On a mission to help confused Rockchip owners get more than just the French and Chinese dance-vids working on their units!
Old 25th Sep 2007, 4:44 am
iixorbiusii , it is likely a Sunplus chipset as there is also a camera, which is commonly found in Sunplus. Also, it supports both .avi and .3gp video format which is common to Sunplus.
Old 25th Sep 2007, 5:52 am
Thanks Lattesurf...
How would you rate Sunplus?? I have various Rockchips, a Meizu M6 and some Action players - and the Actions sit well below the other two types ! Where would you place Sunplus Chipset players, and can they actually handle .avi / xvid rather than .amv etc ??
Cheers!!
Old 25th Sep 2007, 5:55 am
Sorry - just read that bit, so ignore me asking about .avi !!
Old 25th Sep 2007, 6:32 am
Currently i have a Teclast which is the Telechips version but plays xvid (which in a way quite similar to Rockchip), Sunplus (.AVI & .3gp) and Actions (.AMV).
Both the Teclast videos and Sunplus videos are quite the same. Sunplus supports upto 30FPS, so videos appear to be quite smooth.
Definitely video-wise, .AMV format could not be compared to .AVI format.
I'll probably rank Rockchip & Sunplus side by side in terms of video quality. However, Rockchip would still have a slight advantage as the xvid codec allows much smaller sized video files as compared to the pure .avi for Sunplus. i encoded a 3minute+ video at 30FPS (2.4" size), resulted in a filesize of 30MB!
Can't "unlock" 16GB 2.8" Touch Screen MP4 player javitony Dead Players 5 16th Dec 2009 8:15 pm
A tempting selection of new players from ebuyer geostar General Discussion 4 19th Dec 2007 11:46 pm
Dead Player - ATJ2051H - -"Sony" 1 gb "mp4&q dread Dead Players 0 4th Mar 2007 12:04 am
Firmware for "Digital Player MP4" 1.8" 2GB nabilash Dead Players 6 10th Jun 2006 4:27 am
