Inside the Optimus Cosmic player (2.4" 240x340)... Rock
  #41 (permalink)
Old 23rd Oct 2007, 1:40 pm
just got my Ainol v900 ATJ2135 player from i-yotta.com
initial thoughts after a quick play are good - but a few problems that need sorting
so far:
really great sound
nice popup menus
can play FLV (most)
wont play my rockchip converted videos
list songs in ALPHABETICAL order NOT by track number _ BAD BAD BAD
playlists
bookmarking of vids and music - great for audio books etc
the player itself (ainol) - well, more to come but its not good
i am still playing so may have mussed things and am intending a full review of the chip and its functions and small review of ainol v900 player
more to come
  #42 (permalink)
Old 23rd Oct 2007, 2:22 pm
Default Re: Inside the Optimus Cosmic player (2.4" 240x340)...
do you have the firmware?
  #43 (permalink)
Old 23rd Oct 2007, 2:25 pm
no - no firmware on disk and no firmware yet on ainol site
  #44 (permalink)
Old 23rd Oct 2007, 7:41 pm
It surprise me that it weren't able to play your rockchip videos... mine played them without problems :shock:
  #45 (permalink)
Old 23rd Oct 2007, 10:13 pm
it wont play any of the files i have made with Imtoo dvd ripper, but i just tried a couple of sample files of this site and put them on and they worked - so not sure why my converted files wont work - shame cos i have quite a few now - i will have to investigate the files and encoding settings - you know a good tool for this???
BTW Daremos in the music menu is an option called "level" - any idea what this is??
  #46 (permalink)
Old 24th Oct 2007, 5:20 am
It's a bad translation for the stars that appears when you press menu one time. It's the level of stars you give to the song from 1 to 5. I think that "ranking" should have be a better translation or "rating"?
I use two tools for that... one is G-Spot which allows you to watch the videos, and the other is MediaInfo here -> MediaInfo
this show info interactively in Windows Browser
  #47 (permalink)
Old 24th Oct 2007, 5:32 am
thanks for that Daremos
i had seen and used the star rating but never linked it to "level"
do you or have you discovered a way to list music files in a different order - mine lists the alphabetically and not by track number - so it plays them by alphabet and so in wrong order
  #48 (permalink)
Old 24th Oct 2007, 5:44 am
That's proper of your V900 firmware, in mine it display all the songs of an Artist by its tracks number within each album without any separation between them. In other words, correctly, but you see just a long list with no further information. I think indeed its a playlist of two levels rather than a catalog.
  #49 (permalink)
Old 24th Oct 2007, 6:16 am
no - mine definitely listing by sing tag name.
if i go in by artist then i get long list of all songs by that artist, not list of albums then songs.
BTW mine are in WMA wonder if that is a problem of song order - i will check this by loading album of mp3
BTW firmware version on my player
13.00.10.1015 - and plays FLV - did you say yours could play FLV or not
  #50 (permalink)
Old 24th Oct 2007, 9:14 am
Your version is newer than mine
I will pick it up when Ainol put them in their site
Mine doesn't play FLV
it's version 13.00.10.1012
Optimus Touch MP4 Player ANYKA juanlucho Dead Players 1 6th Oct 2009 6:26 am
hello i need for "optimus touch 2ed gen" conankun Firmware 4 11th Jun 2009 7:20 am
"file format" error - can't play vidoes on Rock Ch nathaniel18 Support and How To 13 22nd Feb 2008 7:29 am
[solved] Rock Chip player : i can't open drive Chrisdecooln Dead Players 4 9th Feb 2008 3:24 pm
Video overview of the 'Optimus X' 2.4" Player razzer001 Reviews 3 10th Apr 2007 7:13 pm
