Inside the Optimus Cosmic player (2.4" 240x340)... Rock
Old 13th Oct 2007, 8:46 am
Default Inside the Optimus Cosmic player (2.4" 240x340)... Rock
I am taking advantage of this picture post by our member iixorbiusii to share with this community a very extraordinary player... I do buy it yesterday because I was really impressed by its low price and amazing software.
Externally is the same device but mine is white. It has the same earphone jack on top of the right side, the slot for mini SD a bit below (which appear half open in the picture... as it will be all the time when a card are inserted ... no way to close it)... it has also a couple of useful key on top to manage volume. On the bottom it can be seen the key ON/OFF and the USB port... in a very annoying place... anyway not big problem.
Screen is 2.4 inches with a resolution of 320x240 in 262k colours. Buttons as it can be seen are the same of any chIpod but turned right to keep the player in horizontal way.
Until now everything is identical except that mine is White and iixorbiusii's is Black... but there is another small detail: iixorbiusii's is Rockchip... mine is Action chipset driven!!!
I’ll do soon a review of this player as it has the best software I’ve seen in a MP4 player until now.
For the moment I show all here that the same player can have different chips. Razzer001 could tell us how this can happend as both player are offered in mp4nation.
Old 13th Oct 2007, 9:16 am
Daremo.
Are you sure this is Actions chipset? This player looks like a Rockchip player to me. :roll:
Can you display the firmware version? or can you show a photograph of the insides? :roll:
I can't believe this is actions based. :wink:
Old 13th Oct 2007, 9:47 am
Originally Posted by knob";p=&quot View Post
Daremo.
Well... it isn't... This is a Rockchip chipset... The other one he has is the Action one...
Old 13th Oct 2007, 3:18 pm
Weird! I hope to find out more from Daremos !!
I originally 'billed' this player as the Optimus Cosmic - when I came across MP4Nation and saw it on their site, that's where I got the name from.
However, mine came from one of those random sellers on Ebay, and not from MP4Nation. I have since discovered that the 'Optimus Cosmic' name is in fact unique to MP4Nation, so mine is just an unbranded thing (a bloody good one though!)
For interest here, below is the inside of my player (the actual one showed by Daremos above). I have actually since snapped off the annoying sticking out bit which covers the minisd slot, and replaced the battery for a 850mAh one (the original shown here only gave around an hour of movie playing and the new one gives nearer 3 hours).
On a mission to help confused Rockchip owners get more than just the French and Chinese dance-vids working on their units!
Old 13th Oct 2007, 5:12 pm
Default Re: Inside the Optimus Cosmic player (2.4" 240x340)...
First I have to say thanks for open your player... I wouldn't open mine
When i saw this player offered in a local supermarket I recall your player due to this horizontal position with buttons located at the right. I did asked to be shown because price was affordable for a 2.4" screen of 1 Gb (about US$ 45.-). Beside of that it claimed support for lots of audio formats and AVI (xvid) video.
I was surprised that instead of the usual rockchip firmware which i know so well, I found a very developed software with lots of functions not available in usual rockchip.
Options in menu are 10: Music, Photos, Video, Record, FM, E-book, Games, Tools, Data Exchange and Settings.
Tools is not available in your device and is comprised of Stopwatch, Calculator and Calendar
Data Exchange is a function that its only purpose is to transfer files between Flash memory and mini SD card.
The player doesn't have Browser, instead of that in any of the options which needs to read from folders there is an option named "Dir list" that address to folders and files in the Flash memory or mini SD card.
Another surprise was the parameters for video playback which are of a resolution of 320x240 at 30 fps which is real, as both samples were encoded with that values and I encoded a couple more which played without any out-of-sync issue. Audio for video is MP3 not MP2. I checked quality of video comparing it with my Teclast and Onda, and I have no doubt is showing 262K colours.
Among the setting is Data and Hour that is shown all the time in upper bar in a strange notation as it is 2007Y10M14D for today, also show the time.
When the user enters in Music option appears a list of another options which are: Now Playing, All Music, Artist, Album, Genre, My Music List, Dir List, Record List, My Music Tag List and Level. This show a good managing of ID3 tag, taht really works.
After transferring of files from PC, when USB is unplugged, a process of update files is triggered to prepare song based on ID3 tag.
When a song is being played pressing Menu appears another menu with more functions, as it is: Rep, EQ, Replay time, Replay Gap, A-B, Tempo Rate, Remove, Add to MyList, Information, Add Tag, Fade In/Fade Out and Volume. Most of tne customizable values, it can be set the gap between a song and another in Replay Gap.
When is selected EQ appear common equalization features: Natural, Rock, Pop, Classic, Jazz, DBB plus SRS WOWWHD.
This last option have a couple more: SRS WOW, SRS WOWHD and User mode.
User Mode leads to another menu to put values to SRS 3D, TruBass, Focus, Center, Definition, Speaker Size and Limiter.... geeeez!!
Information of a song are impressive complete, but I wont describe her
Concerning firmware information its version is 13.00.10.1012 which I don't know what this means.
I've write all above, which is a small part of the lots of other menus and option that can be accessed, to show that this is in no way a rockchip device and that this software is by far the most complete of all firmwares I've seen in an MP4.
Concerning quality of sound I have to say that is average not being as good as Meizu, Teclast or Onda... it sound almost the same as an iPod a bit better... anyway I haven't yet used any sort of equalization, which surely would improve its quality especially if SRS is used.
I am still discovering all the goodies of the excellent Action player... it's really exciting though :lol: :lol: :lol:
A Youtube clip of a similar player can be seen here ----> Foston FS-74
Old 13th Oct 2007, 11:44 pm
Wow.:!: Any chance of some photos?? Your player certainly has a host of features not currently in the Rockchips! If yours looks identical to mine apart from the colour, then perhaps the cases are now being made available to different manufacturers.
Perhaps I'd better stop dissin' Action players - these new ones, at least!
Old 14th Oct 2007, 12:53 am
Daremo
I suppose you are not "pulling our legs" on this one.
How can you be sure this player is Actions? did it say so on the box?, did you get a cd with the player?, if so what was on the cd?, could it be another chipset? or just a Rockchip with a new firmware? :roll:
Please give us some more info, we MPx junkies are getting all excited about this.
If this really is an Actions player then it's not Actions as we know it.. :shock:
Old 14th Oct 2007, 1:35 am
it might be some weird mutant cross between actions and rockchip. LoL
Old 14th Oct 2007, 7:08 am
Daremo
I should have had a lot of imagination
I miss to mention that this software is fully multitasking :shock: AFAIK in rockchip players it can't be playing music while are watching photos. In this firmware it's possible. Due to that in every function if MENU button is kept pressed, appears a black sub-menu to the right showing option "volume" to control it from anywhere with the useful couple of keys in the upper border... iixorbiussi for what are used those keys in your rockchip device?
Anyway take a look to the clip I enclosed you... in minutes 00:55 is shown the screen for "Now Playing".
Later is shown in details a screen used for display photos called "File List mode" where appears in a row the file name of photo and a thumbnail on the right. Also photos can be shown just a matrix of thumbnails.
You will think I am a just a liar but in "Photo" sub menu option is another set of options the shows the following: Remove, Rotate, Zoom, Information and Volume.
Rotate: Rotate 90 degrees, Rotate 180 degrees, Rotate 270 degrees.
Information: File Name, Resolution, File Size and Created Date.
It's an Action because when it's switched POWER ON appears the well know hourglass.
I've tried to extract the firmware with S1fwx and of course it didn't work but blocked USB port and spoiled flash memory, deleting all files because it put device in upgrade mode after showing 9.0.48... ... I get a bit in panic thinking in change the device once more time... I recall that in setting there is an option "format memory" and "format card".
So i did format memory and it was restored to its 1Gb with several folders created by default: MUSIC, RECORD, NES, PLAYLIST, TXT, VIDEO, PICTURE. I wonder what this NES folder is... maybe it also have a NES emulator??? .
Gosh!!... this is really an awesome piece of software... during the day I will take some photos.
PS.: I have a backup of firmware taken from a Brazilian site. Size of module is really big (16.639 kb) here is what it show in the file FS74-13.00.10.1012.fwu <--- a strange extension.
PS2: Knob... Concerning Chinese characters in RKLogoEdit... I've found a way to run Chinese software in windows XP without problems. No needing to translate Chinese into Roman (or whatever). here is the link: http://www.ycibo.com/mp4help/ with this I was able to modify my Onda firmware using latest version of RKLogoEdit_v1.0.0.17_relaxed taken from onda BBS (it come with LST embedded for VX858)
Old 14th Oct 2007, 7:22 am
I have been looking for info on the chipset for this player but have not been able to find any yet.
There seems to be modded vesions all over the place, done already by owners!
This will make this a popular player! that is good news for all owners that like to personalise our players.
For sure it's not a Rockchip with .fwu firmware format.
Thanks for all the info Daremo.
PS
err, They can actually, as mentioned on the Rock-Chips website, I think its just the lazy Rockchip programmers haven't bothered to implement it, just like proper Id3 tagging
Optimus Touch MP4 Player ANYKA juanlucho Dead Players 1 6th Oct 2009 6:26 am
hello i need for "optimus touch 2ed gen" conankun Firmware 4 11th Jun 2009 7:20 am
"file format" error - can't play vidoes on Rock Ch nathaniel18 Support and How To 13 22nd Feb 2008 7:29 am
[solved] Rock Chip player : i can't open drive Chrisdecooln Dead Players 4 9th Feb 2008 3:24 pm
Video overview of the 'Optimus X' 2.4" Player razzer001 Reviews 3 10th Apr 2007 7:13 pm
