Legit 4GB?
Old 23rd Oct 2007, 10:06 pm
Default Legit 4GB?
Before i paided for it, the seller confirmed it was 4GB (4000megs)
still waiting for him to ship it cause i just paided for it.
heres a pic of it.
heres the ebay link: NEW IN BOX - 4GB MP3 / MP4 PLAYER - BLUE - VOICE FM REC.
think it will be a legit 4GB?
Old 23rd Oct 2007, 10:54 pm
Default Re: Legit 4GB?
Unfortunately you can't tell whether it's a legit 4GB player by looking at it or from a photo. The only real way to know is to format it and also look at the memory chip inside the player to confirm what size it really is.
Keep us posted when you get your player.
Old 23rd Oct 2007, 11:54 pm
hopefully it will be legit, according to the seller it is, and he is australian by the looks of it, so hopefully wont be a dodgy chinese scammer.
The Message i sent him to state clearly the size.
Hey, I Just won the bid on this player, and it states in the header 4GB, then in the description, Storage Capacity: 4 GB.
But then in a nother part of the page you put
For Auction - BRAND NEW - Mp3/4 Player - 4Gb
4Gb Memory (1000 songs)
4Gb Mp3/4 Player
stating 4Gb not 4GB like in the header and description, im just wanting to know what is it, as you stated 2 different things.
So which is it?
gigabytes GB (Note: uppercase "B") Number of megabytes :1000
or
gigabit Gb (Note: lowercase "b") Number of megabytes :125
His reply
Hi,
The storage capacity is: 4GB = 4000MB
Thanks.
Old 24th Oct 2007, 12:32 am
Hi Zyther.
The probability that this player is hacked is extremely high. In the description there is a clue that this player is a hack.
Look at the memory capacity. It says "4Gb" with a small letter "b". For this player to be a real 4GB player, it should say 4GB with a capital letter B.
4Gb means 4 Gigabits, a very small capacity. 4GB means 4 Gigabytes, a large capacity.
4 Gigabits (4Gb) = 512MB (megabytes). That means this player does not have a large memory capacity.
Hacked sellers do this because very few people know the difference and don't know there is a huge difference between gigabytes and gigabits So when buyers read "4Gb" with a small letter b they think it has a very large capacity. Its not. It means 4 Gigabits or 512MB player because 4Gb = 512MB.
Some buyers simply miss the clue because it is so sutle.
It may be a bit confusing and I hope I've explained it ok. Just know that when you read a player having 4Gb with a small letter "b", you are really looking at a player with a memory capacity of only 512MB, a very small memory capacity. It is not a real 4GB player.
When a buyer complains the seller emails back with something like "the memory capacity was clearly marked 4Gb. You should have known the difference". The seller will blame the buyer.
If the buyer puts in a claim with ebay, the seller shows ebay the description saying "the capacity is clearly marked" and the history of ebay has been to deny the claim.
Check your player as soon as it arrives. The probility that your player is hacked is extremely high.
Old 24th Oct 2007, 12:37 am
Hi Zyther.
While I was getting the message together with the screen shot of the description you must have been writing about GB and Gb. It took me about half an hour to write the message, do the photo and try to find some links about GB and Gb.
I didn't find any good links. But that took some time. You must have been typeing while I was Googleing. :lol:
Just ignore what I said. You saw the same thing as I did in the description.
Old 24th Oct 2007, 5:52 am
The guy doesn't have much feedback as a seller and none as a seller of mp4s. Doesn't look good in my opinion. Probably a known scammer with a new ID. Check it out as soon as it arrives and file a dispute with Paypal.
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
Old 24th Oct 2007, 12:22 pm
I don't know if this will give you any comfort.......but Chinese scammer rogerlam628 told me that he needed to get at least $58US shipped, to make money on a legit 4GB player. With the money conversion, it appears you paid around $58US shipped. So you paid enough to get a 4GB, and if you don't, you need to raise Hell!!
Old 25th Oct 2007, 6:59 pm
well, mine says 4 GB but I'm not sure. can you guys check it out?
Capacity
4GB flash drive
Protects private information by self-defined password
Holds up to 1,000 songs in 128-Kbps AAC format
Holds up to 12,500 photos
Stores data via USB flash drive
Display
1.5-inch (diagonal) liquid crystal display with blue-white LED backlight
128-by-96-pixel resolution
168-mm dot pitch
Support for display of multiple languages and characters simultaneously
Audio
Skip-free playback
Frequency response: 20Hz to 20,000Hz
Audio formats supported: ACT, ASF, MP3, WAV and WMA
User-configurable maximum volume limit
7 presets EQ: rock, natural, soft, pop, classic, jazz, DBB
6 playing modes: normal, repeat one, repeat folder, repeat all, random, intro
2 replaying mode: manual replay, auto replay
Video
Video formats supported: WMV, MPG, MPEG I, MPEG II, and AVI
Convert to AMV
Photo storage
Built in picture/photo viewer
Convert JPEG, GIF, SWF, PIC, etc picture files to be viewed by AMV
Additional features
Built-in clock
e-Book (supports TXT, IRC files)
Games
Inter-changeable animated startup screens
Screen auto shut off to save battery
Support ID3
The lyrics of music files can be shown on screen
Integrated speaker
Old 25th Oct 2007, 10:03 pm
You can check your player here using these instructions:
http://mympxplayer.org/how-to-removi...ck-vt2400.html
Old 27th Oct 2007, 9:00 pm
This seller could also be a past scammer that set up a new account. But this is pure speculation. We'll need to wait till you receive it and formatted it to verify the actual capacity.
A note about Brew Swillis's comment, assuming that the bid does not hit $58, does it mean that the seller would send a hacked player instead? Wouldn't this be fraud? In auctions, there is no guarantee that the bid would reach a certain amount. Unless the seller is shill bidding in the background. But anyway, everyone knows that "rogerlam628" talks nothing but BS.
is onthesource.com legit or not? actmen General Discussion 1 11th Mar 2009 10:23 am
Is Actfind.com a legit site? FMPman General Discussion 6 20th Oct 2008 9:27 am
Looking for Legit 8GB 2.0"LCD MP4 Player WT7-08R Hellfromabove General Discussion 2 1st Jan 2008 5:31 pm
Sourcingmap.com Legit or Not? chiod_O Bad sellers/Blacklist 0 3rd Dec 2007 3:43 am
Wooo got a legit 4GB. Zyther Video related 3 2nd Nov 2007 12:41 am
