Any other method of checking out the true memory of mp4?
Old 26th Oct 2007, 1:43 pm
Default Any other method of checking out the true memory of mp4?
I need to know if there's any other way to check the real memory of the mp4. I downloaded how to remove hack memory and it's not working out for me. It won't let me move the slider on the Partition and Encrypt tab.
Old 26th Oct 2007, 5:16 pm
The memory hack removal process only works on players that use Action chips. If the hack removal process is not working for you then your player may not be Action based. Memory hacking is a problem generally found only on Action based players so if your player is using a Rockchip, Sunplus etc. chiptype then it is highly unlikely that it will be hacked.
De-Hacking Method would not work caLVin Support and How To 11 7th Sep 2008 10:11 pm
Method of Installing the firmware???plz urgent help!!?? dogarsahab Dead Players 0 12th Aug 2008 4:21 am
Can't get to play videos. How to detect true memory? shadow1282000 Support and How To 3 21st Dec 2007 11:33 am
Using s1clone as a backup method Husker Support and How To 5 3rd Nov 2007 7:10 pm
TRUE 4GB FMP?????? FMPman General Discussion - Uxcell.com 14 11th Mar 2007 8:37 am
