Soundwave 2GB MP4 Player
Old 3rd Nov 2007, 1:54 pm
Default Soundwave 2GB MP4 Player
Hi All,
I am hoping that someone here can help me. As of last night my Soundwave Mp4 Player has stopped working. It is showing gibberish when I select the music folder and it won't play music. This player is not even a year old
Please contact me with a reply if you can help
Old 3rd Nov 2007, 10:56 pm
Mys Terri , what is the current firmware version installed? If you can't view it properly, perhaps you could recall it?
If it is an Actions chipset, perhaps a simple firmware extraction/repair/re-flash would fix the problem. If your player is almost to a year old, it might be likely that it could be using an ATJ2085 which would be supported by the tools for the above mentioned procedure.
soundwave mp4 soundwave General Discussion 0 24th Mar 2008 3:01 pm
SoundWave 2gb MP4 player Skydoc Video related 8 3rd Apr 2007 2:43 am
