Firmware is OK, but the code ASSEMBLER or C++ where is ?
Old 5th Nov 2007, 9:34 am
Default Firmware is OK, but the code ASSEMBLER or C++ where is ?
Hi,
I have a ONDA VX858LE firmware.
There are 2 file, 1 .rfw and 1 .lst to change the graphic of menu, but if I want change the code ?
Where is the code? In the ROM ?
HELP ME.
Old 5th Nov 2007, 12:11 pm
The code is in the .rfw file.
But it's not Assembler or C++, but pure machine code so is very difficult to decode, if you want to have a go I suggest you download the Rockchip datasheet in the downloads section and have a look at that first.
http://www.mympxplayer.org/rock26xx-...pdf-df609.html
Old 6th Nov 2007, 6:59 am
Default Re: Firmware is OK, but the code ASSEMBLER or C++ where is ?
Tks, but do you know a software that permit me to modify this code?
Because I have only an editor for the graphic.
Pascal and Assembler : Example WIZARD General Discussion 5 24th Mar 2009 5:17 am
Pascal and Assembler : Example WIZARD Support and How To 7 24th Jan 2009 10:16 am
Source Code for Touchscreen MP4 hydmp4 Firmware 1 20th Jan 2009 9:39 am
Coupon Code nanocopyuser General Discussion - Uxcell.com 2 11th Mar 2007 10:45 am
Discount Code zwaso General Discussion - Uxcell.com 1 13th Feb 2007 1:46 am
