-   -   is this a Onda VX878 (http://mympx.org/forum/general-discussion/39873-onda-vx878.html)
L_o_N_e_R 9th Dec 2007 9:50 pm
http://www.dealextreme.com/details.dx/sku.1578
the menu looks just like it....
its prolly not the onda one but what is it?
makd511 9th Dec 2007 10:34 pm
no - not at all!!!
its just s touch screen player with the UI of the onda - be careful here as there are some clones of the onda out there
its just another no-brand mystery player with no name and you will never find oyt where and when it was made let alone be able to gain any backup or support for it.
dealextreme will sort you out if anything goes wrong, and it probably will,
so avoid if you are wanting an actual VX878 or unbranded VX878
yzdigital 12th Dec 2007 11:00 pm
Re: is this a Onda VX878
There are some pictures for your reference.
http://ad2w.com/t/m2803-m-1.jpg
http://ad2w.com/t/m2803-m-2.jpg
http://ad2w.com/t/M2803_1_600x450.jpg
Our 2.8 touch screen mp4 player (Model: M2803) build in bigger Li-polymer battery(1800 mA) . It is about 40 hrs for playing music by the situation of black screen , volume 20 , using earphone.
And this player support double non-damage audio formats (APE、FLAC)
makd511 13th Dec 2007 4:25 am
YZ
can your player accept the ONDA firmware updates as they are constantly updating this.
i know there are so called different version out there as well, what these are i do not know.
but me personally would buy an onda and be assured to get updates
there was also an issue with languages resetting and touch sensitivity so updates are definately needed
have you tried to update the firmware??
cheers
DaremoS 13th Dec 2007 4:36 am
That's not an Onda VX878 but an Onda VX858 as it has a screen of 2.8. VX878 sport a screen of 2.4".
Onda VX858 has a couple of models which are VX858 and VX858LE... LE is a cheaper version that doesn't have a Wolfson audio chip.
Both version aren't compatible and interchange of firmware blocks the device.
Only opening the case you can know if it is a LE or non LE model ... it has a extra chip which is Wolfson one.
Can be noticed in the second picture where is read clearly VX858LE.
If the open case belongs to such machine it's seen next to battery cables a empty space where it should be Wolfson chip (it's a square grey space, while the chip are seen black)
makd511 13th Dec 2007 10:39 am
well spotted DaremoS - missed that completely - and these people are supposed to be manufacturers - or so their web site claims :)
jo gobel 13th Dec 2007 11:03 am
Originally Posted by makd511";p=&quot (Post 42247)
YZ
cheers
I have one of their players and it is great.
the firmware is upgradeable, but it uses the NON Onda OEM firmware. You can locate usable firmwares for this player (YZ Digitals model) here...
http://www.mp4nation.net/software/MP4-En-V1.10.rfw
or if you want to use a modified version of that firmware that shows the "Onda" logo on startup and shutdown along with Onda's USB and Charging screens, a mp4nation.net users modified that firmware and has it hosted here... http://www.megaupload.com/?d=0MV0H6SJ
i personally have loaded the modified version onto my YZ Digital player and it works flawlessly.
dapman 13th Dec 2007 5:27 pm
if your player do not work with real onda firmware from onda website or support you do not have a real onda or onda oem player, you just have a cheap copy. The is no such thing as Oem firmware because Oem and the real thing are the same they are no difference between the to just a name and a logo. The firmware on mp4 nation that your are talking about does not update the features and performace of th player.
Sorry YZ your player is just a copy or a look alike of the real thing as you showed in your picture. You are not onda factory or the factory that onda buys from so your player is not a oem product it just makes it a copy or fake.
DaremoS 13th Dec 2007 5:38 pm
Who told you all this shit you're saying pal?... There is no such crap of OEM with Onda logo!
I have a no branded Onda VX858 that works fine with Onda firmware... I've installed wrong firmware for fun and I've been capable of recover it... you simply are repeating some shit you read in Mp4users.com or somewhere.
A copy for your knowledge in Chinese factories is almost identical to an original... there is no big difference because chip are simple cheap... is easier to copy the whole package than design a cheap copy.
Stop repeating pure bullshit.
The problem with VX858 is that it can be a VX858LE which is risky but can easily be recovered.
dapman 13th Dec 2007 7:26 pm
I work for a US Brand company and I have been to the major factories in shenzhen.
from jo globel " a modified version of that firmware that shows the "Onda" logo on startup and shutdown along with Onda's USB and Charging screens, a mp4nation.net users modified that firmware and has it hosted here... http://www.megaupload.com/?d=0MV0H6SJ"
This firmware is not from onda if your player play this firmware you do not have a Onda or Onda oem player. You have a copy or fake
Go to www.Onda.cn download the firmware for the VX858 or VX85LE if one of them work you have a Real Onda or a Real Onda Oem player.
Onda players are made by Ecom factory. Onda buy them and add there name and logo to the player. Real Oem VX858 with wolfason sound chip true name from factory EMP2801, then onda sells them unda the onda brand name. If your player was not made by the Ecom factory you have COPY or a FAKE.
