help in selection of firmware
Old 16th Dec 2007, 4:07 pm
Default help in selection of firmware
Hello guys i am new here and actually don't know what a firmware is
i have a sony MP5 made in japan Version v4.01.070920-d
Now can you please tell me which firmware to install and some links to the themes which can be installed
and it doesn't have fm is it possible to install a fm software
thanks
krates
Old 17th Dec 2007, 3:18 pm
krates , if your player is working fine, do not perform any firmware updates. As it would more likely brick it instead rather than improving it.
As for theming, it depends on your current firmware and chipset used. Have a look in the System/Settings menu, then select Firmware Version/Info. What does it say there?
Old 17th Dec 2007, 4:53 pm
Hey it show me this
Version
v4.01.070920-d
any suggestion's Click the image to open in full size.
[solved] Video selection only says "Empty Disk" satdog75 Video related 3 27th Dec 2008 10:07 pm
A tempting selection of new players from ebuyer geostar General Discussion 4 19th Dec 2007 11:46 pm
problem selection songs sonicexenia Support and How To 2 26th Jan 2007 5:44 am
