Sunplus SPMP3050A - General
  #91 (permalink)
Old 29th Mar 2008, 4:51 pm
Here they leave a frankenstein of mp4 of the photo of the first post for which they died as my guard and did not amiss but at least you can listen to music, watch Films, take Photos and filming jejeje if someone who understands more than I would modify and make it work is perfect Or whoever has the original which posteen.
And this may prove mahmoodhassani could see you walk because it is the firmware and the images of the disk of your device with some modifications
Mi ingles es horrible jaja :lol:
PD: si no funciona con SPMP3050A.BIN prueben solo actualizando el firmware con el DefaultFw.bin
la url para descargar
http://rapidshare.com/files/103412518/Firmware.rar.html
  #92 (permalink)
Old 30th Mar 2008, 1:20 am
hi
thanks my mp4 image is like below:::::>
[align=center]Click the image to open in full size.
hellp---i just need orginal files
  #93 (permalink)
Old 7th Apr 2008, 7:24 pm
Para los que tengan este pmp muerto aca esta la solucion
http://www.psicofxp.com/forums/gadge...mwares-10.html
  #94 (permalink)
Old 23rd Apr 2008, 2:52 pm
Hola yo tambien tengo este mismo reproductor (el que parece "psp").
al tratar de montarle otra imagen u otro firmware me pasan dos cosas
1 se queda atorado (supongo que por incompatibilidad)
2 o enciende bien pero cuando ya esta en el menu principal no me funciona ningun boton
si alguien sabe como solucionar el problema porfavor ayudenme
gracias
(sorry for my English)
hi I also have this player (the one that is like a psp)
when i try to mount other image or firmware, i have 2 problems
1 it dont work(i spouse that is because a incompatibility)
2 the player turn on but when it is in the main menu the buttons don't work
if someone knows haw to solve the problem, please help me
tnx
  #95 (permalink)
Old 5th May 2008, 3:42 am
hi guys.... pls help
my mp4 player is not detected by my pc...
this is what my player looks like
what button do i hold to make it as a webcam
  #96 (permalink)
Old 6th May 2008, 5:30 am
Reflashing is unlikely to fix the detection problem. I had the same problem and it's caused by non-standards compliant usb chip used on the device or by bad initialization of this usb chip. You can still access files stored on internal flash if you connect it to an usb 1.1(not usb 2.0) capable pc. You should also be able to access sd cards on any pc if you have one. This "bug" is does not affect firmware upgrading so you should be able to do that on an usb 2.0 pc.
Anyway, here are couple ways around this problem:
- use your device on an usb 1.1 capable pc
- go get a sd card and put your files there(your pmp has menu option to select active "drive")
- somehow remove usb 2.0 support from your system making act like usb 1.1 (should work in theory) *
- use usb 1.1 only capable usb hub between your device and pc (again, should work in theory)
- fiddle with your pc's bios settings in hopes of being able to affect usb timing. fsb(Front side bus) speed is the one you could try changing.
If you re-read this thread, you should find two firmwares for this device, along with description of where the "webcam button" is. These firmwares are incompatible as far as I can tell. fw posted by me is older and less capable.
* usb 1.1 is also known as ohci(Open Host Controller Interface) or uhci(Universal Host Controller Interface ) and usb 2.0 as ehci(Enhanced Host Controller Interface)
  #97 (permalink)
Old 6th May 2008, 6:23 am
can i upgrade my mpx player by putting the files in the sd card then running the upgrade on the tools menu?
  #98 (permalink)
Old 6th May 2008, 6:45 am
I haven't tried. I wouldn't try it without a backup of firmware because of the high risks involved. Both of these firmwares might be incompatible with your device and you might never be able to get a working firmware again. And it probably wouldn't do any good since you probably already have latest compatible firmware anyway. You can check the firmware version from menu and compare it with ours.
Anyway, SPMP3050A based devices only support usb 1.1 so transfering files to/from device is slow as hell. sd is faster if you have a decent usb sd card reader and memory.
  #99 (permalink)
Old 7th May 2008, 3:50 am
my players version is v4.01.080319. would you by chance know its "webcam button"???
thanx for the help
  #100 (permalink)
Old 7th May 2008, 7:52 am
Its in line in. Multimeter lead I have in that picture is ideal for the job.
Your firmware version is newer than zerdrakon's (V4.01.070910-b) and mine (v4.01.071023-d).
Can you upload it somewhere so we can test it?
