Sunplus SPMP3050A - General
  #101 (permalink)
Old 9th May 2008, 8:48 pm
can i have the aimg bimg and fw for the mpx player shown here
http://www.dealextreme.com/details.dx/sku.10238
... my technician just fucked up my mpx without backing up the files... the jerk...
the aimg im looking for doesnt have dictionary, no calendar, no fm radio, no alarm clock... and its default language is english...
  #102 (permalink)
Old 11th May 2008, 9:50 pm
i have flashed my mpx player now but the screen is flickering. the main menu is present but when is turn the mpx on... it loads the main menu with a short beep sound... i cant access any of the menus by pressing ok... i can just browse through the menu...
i used the aimg, bimg and fw found in here...
http://www.mympxplayer.org/dead-pmp-...de-vt9087.html
  #103 (permalink)
Old 19th May 2008, 10:21 am
kyur4 th ich, try http://www.megaupload.com/?d=FINFQ4EZ . http://mp4.itram.es/wiki/spmp305x/firmwares has couple others too.
  #104 (permalink)
Old 25th May 2008, 1:23 am
@Heru Er
I have the same pmp you posted with 2gb memory (same as picture at first post and as mahmoodhassani -apart from memory...)
It did not last an afternoon!! Sometime suddenly, when I saw empty folders, I pressed the reset key and from then it is dead completely
Only the two lights turn on....
You posted a link in spanish, but cannot read it!!
I managed to install drivers for FRM pro, tried to backup firmware, but I faced problems...
(failed with AIMG and BIMG and stuck for hour with DefaultFW.bin) It created 1.85 GB file with DefaultFW.bin and I manually stopped it!!!
can you (or someone) help me please??
  #105 (permalink)
Old 26th May 2008, 7:27 am
Originally Posted by xeirwn";p=&quot View Post
@Heru Er
Suicidal hardware is always fun. Or maybe flash signed off.
Just go to http://rapidshare.com/files/103412518/Firmware.rar.html , click "free", click "Download via xxx" etc. , extract and burn.
  #106 (permalink)
Old 26th May 2008, 8:56 am
thanks aapot for reply...
actually, I had it downloaded, the exact file you proposed to me!
by experimenting, now I managed to flash only with ISP 5.2 the DefaultFW.bin, but this did not fix my mp4 player...
the problem is that the PC recognises the mp4 as a webcam ONLY if I plug it in a new USB port!! so I think I am running out of USB ports to test again... any solution on this :?:
the FRM pro (which I think I cannot use..) gives me this log:
[Dev NO.Undefined]: Check ISP core -- SUCCESS --
[Dev NO.Undefined]: Get RSV A Image ...
[Dev NO.Undefined]: Get Disk Image -- SUCCESS --
[Dev NO.Undefined] -- FAIL --
FRM_ERR_FAILED(57) -- !
[Dev NO.Undefined]: Get RSV B Image ...
[Dev NO.Undefined]: Rsv Info Get...
[Dev NO.Undefined]: Get Rsv Info -- SUCCESS --
[Dev NO.Undefined] -- SUCCESS -- !
1 devices Detected !
FRM_FW_PATH_ILLEGAL(39) -- !
How can I flash AIMG and BIMG only ? The guide (posted here http://www.mympxplayer.org/dead-pmp-...te-vt9087.html ) is not clear on this...
please help..!!
  #107 (permalink)
Old 26th May 2008, 7:15 pm
Trying with another pc might help if theres some problem with usb.
Sure you selected working folder from advanced tab?
"RSV Only" option flashes only disk images.
  #108 (permalink)
Old 27th May 2008, 10:42 am
I had some success after lots of experiments...
about usb, I realised that I dont have to re-install the driver all time,
I just have the mp4 turned off, and plug in to PC when I press the X button at the same time...
FRM pro works now, I used "Firmware/ Set file " but still cant figure this about the whole AIMG + BIMG..
BUT still the only best firmware from all I tried is this one
http://www.4shared.com/account/file/...P_SUNPLUS.html
The mp4 recovered from the dead, but with a lot of bugs:
The screen is mirrored from right to left (!!) :shock:
the screen flashes all the time, the sound is terribly LOW!!
the menu has FM radio, while my mp4 didnt have it (it doesnt work though!)
the camera, game, DV dont work as well
usb (u-disc working mode..) doesnt work
keys are all good :lol:
I am sure my initial firmware had more items at Tools (like upgrade!) so I look forward for someone to share the original firmware (AIMG+BIMG).. :!:
  #109 (permalink)
Old 27th May 2008, 1:12 pm
Default Slide Panel Firmwares
Hello, I've have the slide panel pmp too.
http://www.dealextreme.com/details.dx/sku.9504
I've back up the Aimg and Bimg, but I forgot back up the file DefaultFw.bin, then i downloaded the firmware from the download section. But now, with this firmware, i can't play games, because when i try it, the mp4 get frozen.
When I compare between my back up Aimg and the downloaded Aimg, I realize that, the size between them are diferent, 49152 KB and 48898KB.
Any Idea or firmware to do my mp4 work again?
Thanks.
Hola, Yo también tengo el mp4 slide panel
Cuando intenté acutalizarle hice copia de AIMG y de BIMG, pero olvidé hacerlo de DefaultFw.bin, entonces descargué el firmware de la sección de descargas, pero ahora , con este firmware, no puedo jugar a juegos, debido a que se me queda bloqueado cuando lo intento.
Si comparo entre mi backup de Aimg y el descargado veo que hay una diferencia entre ambos de tamaño, 49152KB y 48898KB.
Alguna idea de como hacer funcionar correctamente mi mp4?
Gracias.
  #110 (permalink)
Old 28th May 2008, 12:43 pm
Hi. Can you please help me about my digital mp4 player... I bought this player without any installation CD on it......
This is my mp4 player:
sunplus SPMP 3050
I have downloaded the FRM pro software/driver at this website but it can't detect my player..... Is there a USB driver for this installer??? If there is can you share it to me or please post a site where I can get it, or a thread here in the forum where I can find it..... Thank you for your help!!!!
