Sunplus SPMP3050A - General
  #181 (permalink)
Old 19th Feb 2009, 9:42 pm
I too bought one from here
http://www.homeshop18.com/shop/u/y/p...lI_2-q_imedia-
its been one year now..it was working perfectly..but somehow yesterday when I was playing an nes game it crashed and now it does'nt even switch on.sometimes it does but crashes
I think I need to reload the firmware.Plz provide me with step to step instructions as I have little knowledge about all these.
not to forget it had a blue background behind the menu.So plz tell which firmware is compatible.
thanks
  #182 (permalink)
Old 23rd Feb 2009, 11:30 am
hi fr9 plz
i want mp3 and mp4 softwer
plz help me
  #183 (permalink)
Old 26th Feb 2009, 1:29 am
Originally Posted by zenitraM";p=&quot View Post
All right, I managed to connect my MP4 (as I don't know its model or anything, i'll refer to it as 9504, item number on DealExtreme).
Mine does have a different Sunplus firmware from the rest. It's got a blue background and well, it emulates GB/GBC and this strange game format I talked about before, .BIN, games on that format seem to be made by Sunplus and I only have found the 3 ones that came on my player's memory, you can download them from here: http://uploaded.to/?id=yn9jon&setlang=en
I'm now uploading the firmware and the disk A and B images for you to test them. Upload all the firmwares you have so we can test if they're compatible between players and if we can find any extra features.. Skinning is quite easy, just requires modifyng the .jpg's. I think there's no risk of bricking the device, as the FW download feature isn't dependant on the firmware itself (at least while pressing a key when plugging the USB port, only way for me).
Upload the diska and diskb images too, I think they're also needed (I downloaded the .bin firmware from the download section, but the screen showed gray and the unit hanged, maybe because of those images being not compatible).
BTW you may need to modify the USB device ID on the .inf file of the driver so it detects your device. When on this firmware mode it detects as a MMCatch Multimedia Device or something similar (not as a storage device).
Oh, and looking at the images, it seems there's a scientific calculator somehere on the firmware.. but I can only access a simple calculator..
NES and GB emulators are called, according to the hex editor, N1 and G1 respectively.
Edit: Here you have the firmware: http://zen.itram.es/files/PMP_DX_sku...background.rar
THE LINK ISN'T WORKING...PLEASE UPLOAD AGAIN
  #184 (permalink)
Old 2nd Mar 2009, 2:48 am
pls firmware aj280 v8
this is pic
http://bbs.mydigit.cn/attachment/Typ...3c4e537bc8.jpg
  #185 (permalink)
Old 4th Mar 2009, 6:50 am
Salwa Brother
What the Actually Problem with Your Player?
  #186 (permalink)
Old 21st Mar 2009, 7:40 am
I try to use "FRM Pro" but when i click "Dev Detect Begin" the log windows remain empty.
I'm not able to install driver. The device is in explorer windows as a disk.
My Device is this:
How to do?
excuse my english.
  #187 (permalink)
Old 22nd Mar 2009, 5:17 pm
You have to hold down some button while starting the device, for me it is the "camera" button. Then it will get detected as "ICatch" camera device or something like that.
  #188 (permalink)
Old 21st Apr 2009, 6:37 pm
@aapot
You need this driver: http://light.dnsprotect.com/~blld/sp...50a_driver.zip
Sir, can you please update the link... your favorable reply will be much appreciated. thank you
  #189 (permalink)
Old 2nd Jul 2009, 12:17 pm
Hi, I am from Brazil (sorry, my english sucks) I have a "Powerpack mfca-280" that uses the SPMP3050A.BIN firmware. the firmware that came from my PMP can run .nes .gb .gbc and .bin files. I downloaded another firmware from the powerpack's site, that's is totally different. Then I hex edit this firmware, and I found strings inside file called ROM_EXEC support for files .nes .gb .gbc .sfc .smc (SNES)!!!!!!!!! but, i need help to upload this firmware to my PMP, if it is possible. link: Powerpack filename: MF-CA-280.rar Thanx.
  #190 (permalink)
Old 14th Jan 2010, 1:51 pm
Hey.I watched this thread on the old website.Then I found out that the webiste moved.Anyway, I wanted to post some links i've found.
Openschemes.com - Articles Building the spmp3050 arm-elf-gcc toolchain on Fedora for idiots like us
libspmp3050 - Project Hosting on Google Code
I am also interested to use linux on those Sunplus PMPs.I hope, those links will help you guys.
