Sunplus SPMP3050A - General
  #41 (permalink)
Old 15th Feb 2008, 6:58 am
Originally Posted by aapot";p=&quot View Post
Originally Posted by dbg4870";p=&quot View Post
Mine plays GB, GBC, and NES games no problem BUT you can't control the volume in the games. Does anybody know how to fix that?
Try adjusting volume from video player. Works for me.
I can adjust the volume in video and audio players, but it has no effect on game volume. Games play full blast! :?
  #42 (permalink)
Old 16th Feb 2008, 2:28 am
here is the driver you need so that the pc recognise it as a camera and that you can backup it driver
mine the a drive is around 50 mgabytes and it doesnt play gb\gbc games only nes games and i hate them they are silly
and y cant i change the style i mean the theme and the pics :cry:
  #43 (permalink)
Old 16th Feb 2008, 4:44 am
hi! aapot send me your firmware for testing in my device!!! joel.zerpa at gmail.com i will test press "hidden button" in line-in (how? insert line-in cable? Please!!!!), i see when open my device. My firmware is 4.01.070910-b
  #44 (permalink)
Old 16th Feb 2008, 4:57 am
....nothing...i insert a cable in line-in (for press hidden-button) slot and nothing the device is not webcam only flash memory option is enabled....some information for activate webcam and replace firmware?
  #45 (permalink)
Old 16th Feb 2008, 5:04 am
BattleToad (J) Work! NOT Battletoad (E) or (U)
  #46 (permalink)
Old 19th Feb 2008, 11:22 am
I already gave you a link to my fw.
You need something longer than normal 2.5mm plug.
I have personally found multimeter test leads to be close to ideal. Something like http://news.thomasnet.com/images/large/025/25206.jpg
except longer. If you have something with a cone-like head and it's not too small, it should work fine. Head of the button is small though so hitting it with a needle might be rather frustrating experience.
Anyway, I couldn't get the webcam to work when I tried it. Driver apparently crashed windows when launching capturing software.
Also tried a-data speedy 2gb sd with this and it works fine. SDHC card are probably not supported though. Also it seems that these access sd using usb 1.1 so it's rather slow.
BattleToads japan and usa versions hang when entering level 3. eu version doesn't but runs 1'st and 2'nd levels at reduced speed. In third level, objects are flying above ground. Haven't gotten past level 3 yet. Ps. if I remember correctly(it's been ~10 years), there should be a "teleport" in one of the walls that will get you to next level. It might actually be that thing on 2'nd picture at http://www.retrojunk.com/details_articles/1199/ .
  #47 (permalink)
Old 21st Feb 2008, 3:42 pm
hola ,quisiera saber como hacer un update en el pmp (slide panel) .se puden poner mas emuladores (snes ,gb ,sega genesis )??
para charlar mas sobre el pmp (diegoanes@hotmail.com
gracias !
  #48 (permalink)
Old 22nd Feb 2008, 1:03 am
gracias !
Si averiguas cual es la combinación de teclas para poner el PMP en modo webcam en el PC para poder acceder al firmware, por favor, no dudes en colocarlo por aquí. Gracias.
  #49 (permalink)
Old 22nd Feb 2008, 7:23 am
para poner el pmp en modo web cam, apretar (ok +A )con el pmp apagado y conectarlo al usb,asi lo reconoce como una web cam, instalar los driver
saludos !
diego
  #50 (permalink)
Old 22nd Feb 2008, 9:31 am
I've write this guide to help on recovering , I think it may help:
http://www.mympxplayer.org/dead-pmp-...de-vt9087.html
