Sunplus SPMP3050A - General
  #51 (permalink)
Old 22nd Feb 2008, 4:18 pm
This thread sure has evolved a lot since last time i came here. I might pick up one of those players just for kicks if i can find them around.
Heh, that'd make me an "MPx-a-holics Anonymous" member indeed. :P
  #52 (permalink)
Old 23rd Feb 2008, 2:24 am
I created a wiki (based on the GamekingII one) so we can put on there all the information we find:
http://mp4.itram.es/wiki
The Sunplus section can be found here:
http://mp4.itram.es/wiki/spmp305x/
Everyone can edit, so add whatever information you find..
Beerzerk, do you give me permission to copy your tutorial on the wiki? (giving you credit, of course). It's better written than the one I made (and I think you based yours on mine, at least the VDK part )
  #53 (permalink)
Old 23rd Feb 2008, 4:16 am
hola ,alguien podria traducir al castellano el tutorial,para la modificacion del sunplus 3050 ?desde ya muchas gracias !!!
  #54 (permalink)
Old 23rd Feb 2008, 12:10 pm
Hola, qué tal?
Yo tengo éste PMP: http://articulo.mercadolibre.com.ar/...vio-gratis-_JM pero es de marca DCTechnology... tiene un procesador Sunplus SPMP3050A HL171.
El tema es que no puedo hacerlo funcionar como webcam, a pesar de que apreto las combinaciones que dicen. Leí por ahí que hay un "botón escondido" en la salida de video... puede ser??? Dónde? Cómo lo presiono?
Tambien quiero hacerle un upgrade del Firmware, porque no puedo ver la fecha...
Bueno, gente... les mando un saludo y gracias!
English (poor one): Hi! I have this PMP: http://articulo.mercadolibre.com.ar/...vio-gratis-_JM but it's a DCTechnology one whit a Sunplus SPMP3050A HL171 processor... the thing is that I can't make it run as a webcam, even tough I've pressed the buttons combination they say around. I've also read that there's a hidden button in the out video line... is it real??? where is it? How do I press it?
I also wanna make a Firmware upgrade because I can't see the "date" item...
Well... thanks everybody!!! :P
  #55 (permalink)
Old 24th Feb 2008, 6:30 am
Originally Posted by pollo_argento
Hola, qué tal?
Originally Posted by pollo_argento";p=&quot View Post
Hola, qué tal?
hola pollo argento :agregame a tu msn ,asi podemos charlar mas de los pmp ,yo tambien lo compre en mercado libre
saludos
diego
(diegoanes@hotmail.com)
  #56 (permalink)
Old 27th Feb 2008, 3:03 am
QUE VERCION Firmware upgrade SE LE PONE AL SUNPLUS 3050?Y QUE MODIFICACIONES TIENE ??EL QUE LO SEPA ,POR FAVOR QUE LO PONGA
GRACIAS !!
  #57 (permalink)
Old 3rd Mar 2008, 7:51 pm
soz soz is offline
After examining the firmware of my gameking II clones I find the GB and SNES emulators ( SPMP_G1_12M.bin, SPMP_N1.bin, SPMP_N1_12M.bin, SPMP_25MN1.bin ),but gameboy and SNES game ROMS are not recognised when copied to GAME directory.Any ideas?
  #58 (permalink)
Old 3rd Mar 2008, 11:46 pm
My guess is that those files aren't enabled in 3050ABin0.bin thus making them just something they forgot to delete. You can probably remove them and it would still work fine. Someone with working gb/snes emulation could try removing these and see if it still works.
Then again, I cannot find any references to these files in any other file in AIMG(PMP_DX_sku9504_blue_background.rar) .
Maybe it checks every .bin file in AIMG root. Finding such a piece of code in 3050ABin0.bin(in hopes of enabling this feature in other fws) is pretty hopeless.
  #59 (permalink)
Old 6th Mar 2008, 5:00 pm
soz soz is offline
Thank you.
In my firmware several files can be deletet without affecting the toy.Some big .jpg files are not in use,and a unused skin .bmp file with chinese/korean font ( ??34h.bmp ) gave read errors when downloading the A tree as separate files to computer with FRM Pro.
I have tried to burn pacman.nes into GAME directory on drive A without success.
Are structure:
drive A: program files/resources
drive B: swap
drive C: hidden with defaultFw.bin
drive D: flash drive
drive E: SD card ??
or where does defaultFv.bin go?.There seems to be a 2 mb size limit for defaultFv.bin in FRM Pro.
  #60 (permalink)
Old 11th Mar 2008, 2:37 pm
Hi, I have the same player as the first picture of this thread, or at least that is how it look. I already try plug in the usb pressing all buttons and in all combinations of 2 buttons, I also open the case and look for a secret button, but there is nothing inside. If the player is off, when I plug the cable it only turn on, but it doesn't connect to the usb interfase, I have to plug it when it is in the main menu to the PC to see the device. Another thing I looked is, nor in the system setup option, nor in the tools option there is a option to see anything about the firmware version (I saw some screenshot around the web that shows some option inside one of this options). So, anyone have some idea to get and/or upgrade the firmware of this player? (Oh, I already try to conect the cable when it is in DV or Camera mode).
Another thing, misteriously, a .sav file apeared in the game folder, i don't know how this happend (i don't have that .sav in my PC) nor how use it. Anyone knows how this could happen and how to use this .sav file?
Well that's all ^^
