Sunplus SPMP3050A - General
  #71 (permalink)
Old 15th Mar 2008, 1:26 pm
I'm not so sure lycan2005, i've just find a firmware from a different player and even when it has a little different button layout, it is now usable, and it has realtime clock an option for make updates (i don't know how it works, i haven't test it yet) and i won't be surprise if I found something more.
It's true, there are severals models with the same processor that use different firmware (probably because they use different peripheral hardware). But it's also true that evidently there is some important difference in the instruccion set of the differents SPMP305x processors. I think, if we collect a couple of firmware more and classify them carefully, we can begin to underset how it works.
By the way, the firmware I'v just tested is the one from en.s1mp3.net for the spmp3050a-pmp701. Now i'm able to use the full pmp, but it's still a bit annoying because of the changes in the buttons (in the nes emulator the layout it's almost the same and arrows are ok).
Anyway, I'm still looking for the original firmware of this player, so if somebody have it I would be very thankful to revice it.
En español:
No estoy tan seguro lycan2005, acabo de encontrar un firmware de otro reproductor y aun cuando tiene una pequeña diferencia en la configuracion de los botones, ahora es usable, e incluso tiene la opcione de reloj y una opcion para hacer updates (no se como funciona), y no me sorprenderia encontrar alguna otra funcionalidad).
Es verdad, hay muchos modelos con el mismo procesador que usan distintos firmwares (probablemente porque usen distinto hardware perisferico). Pero tambien es cierto que evidentemente hay algunas diferencias importantes en el set de instrucciones de los distintos procesadores de la serie SPMP305x. Creo que si recolectamos algunos firmware y los clasificamos cuidadosamente, podremos empezar a entender como funcionan.
Por cierto, el firmware que acabo de probar es el que se consigue en en.s1mp3.net para el modelo spmp3050a-pmp701. Ahora puedo usar todo el pmp, aunque todavia es un poco modelo a causa de los cambios en los botones (en el emulador de nes la distribucion es casi la misma y los direccionales estan bien).
De todas formas, todavia sigo buscando el firmware original de mi reproductor, asi que si alguien lo tiene estaría muy agradecido de recibirlo.
  #72 (permalink)
Please, if someone knows how to delete a post... this page doesn't work me too fine and my browser send various requests, and this is the result...
  #73 (permalink)
Old 15th Mar 2008, 1:27 pm
Idem
  #74 (permalink)
Old 15th Mar 2008, 1:29 pm
Idem
  #75 (permalink)
Old 15th Mar 2008, 1:37 pm
Entiendo y pido discupas por haber adelantado el comentario, acabe de probar y si efectivamlente funciona
Sorry
  #76 (permalink)
Old 15th Mar 2008, 2:05 pm
Ahí va el SPMP 3050A (AIMG,BIMG,DefaultFw) originales
lo acabe de subir http://www.megaupload.com/es/?d=FINFQ4EZ
Son de este:
http://www.dealextreme.com/details.dx/sku.10238
suerte.
  #77 (permalink)
Old 15th Mar 2008, 7:19 pm
Gracias, pero tampoco parece funcionar. Parece que voy a tener que esperar a que aparezca alguien con el mismo modelo que yo.
Thanks, but it doesn't seems to work neither. It seems that I'll have to wait someone that have the same model come around.
  #78 (permalink)
Old 15th Mar 2008, 9:17 pm
Tengo una duda, cuando abre las imagenes estan todas las aplicaciones, alguien sabe como se debe modificar las imagenes para que se activen las demas aplicaciones por ejemplo si se abre la imagen A ahí va estar muchas aplicaciones pero cuando se pasa al pmp tan solo aparecen algunas.
creo que hay que modificar los archivos .bin ¿alguin sabe como se hace?
  #79 (permalink)
Old 16th Mar 2008, 9:09 am
Deberias modificar el defaultfw.bin y/o el spmp3050a0.bin de la imagen A. El problema es que sin un compilador ni un desensablador es muy jodido de hacer.
You should modify the defaultfw.bin and/or the spmp3050a0.bin from A image. The problem is that without a compiler nor a disassambler it's something very hard to do.
  #80 (permalink)
Old 16th Mar 2008, 11:41 am
Me paso algo muy curiso lo voy acontar para que lo prueben:
Analizando varias imagenes me tope con que hay un archivo que se llama USERCONFIG.BIN si lo abre con el editor de texto se daran cuenta que hay unas opciones como:
USERCONFIG
LCM = 1 (ni idea)
HOME = 3 (supongo que es el skin o modo del programa )
RTC = 0 (ni idea)
KMMEM = 1 (Este numero no varia)
si analizan ese archivo con otros se daran cuenta que los numeros varian.
Lo que hice fue reemplazar ese archivo por otro de otra imagen y el resultado es que curiosamente me apareciron otras cosas en el pmp.
NO SE SI FUE POR ESO.
Ahhh a cuando queme la imgen en el pmp salio un error pero lo desconecte y lo encendi y fue normal
