Sunplus SPMP3050A - General
  #81 (permalink)
Old 18th Mar 2008, 5:55 am
Default Sunplus SPMP3050A
Hello , Bonjour
Like everybody I bought a PMP for my son , I 've taken in Rue Montgallet :
It' an WESTREND GAME-800
It's great !!
I've extracted the firmware by FRM Pro , and now I would like making a new GOOD translation in french ..
Help ! Thanks
  #82 (permalink)
Old 18th Mar 2008, 5:56 am
RTC parece activar el reloj del MP4; si no tienes reloj no funcionará y cada vez que lo reinicies volverá a 00:00.
SKIN parece cambiar entre diferentes modos de skin, activando la radio y otro modo llamado "VideoRec".
(talking about userconfig.bin)
RTC seems to activate the MP4 internal clock; if it doesn't have any clock it sticks at 00:00.
SKIN seems to change between different skin modes, activating the FM Radio (useless without onboard radio) and a not working mode "VideoRec".
reno7: Could you upload somewhere the firmware (AIMG, BIMG, DefaultFW.bin) so we can investigate?
  #83 (permalink)
Old 18th Mar 2008, 6:19 am
In my device I try to change the FW but could not put some of those that are available whenever the program I threw error "SIZE TOO BIG" so I determined that my device has a memory ROM with a size of at least 20 MB and which exceeds there can not be installed. I think I am going to buy a GameKing II :twisted:
  #84 (permalink)
Old 18th Mar 2008, 7:54 am
Hi reno7,
To make translations you have to mount the firmware file called AIMG or extract the contents with MagicISO then you'll find a file in the folder: ro_res\language\. You can modify that file with a hex editor, although I do not recommend it.
Oh, and please go to www.rapidshare.com and upload your player's firmware, as zenitraM suggested. This way we can increase the collection and help others when they brick the player (and also make research).
A COOL thing i found in sunplus players: You can fast forward and rewind at 2,4,6 and 8X speed!!! Just hold left/right and when it starts to forward, release the button and press it again a few times. It will then skip much much faster .
  #85 (permalink)
Old 18th Mar 2008, 7:58 am
Hi , my firmware ...
  #86 (permalink)
Old 18th Mar 2008, 9:34 am
Thank you very much!
  #87 (permalink)
Old 19th Mar 2008, 6:22 am
alex2pb, thanks for uploading your firmware, but it didn't work either (it shuts down after menu appear). Anyway, somebody has to have my player, it's only a matter of time
  #88 (permalink)
Old 19th Mar 2008, 6:43 am
Strange thing, my player shuts down too with Reno's firmware. I guess the board serial must be the same to get it working.
Anyway, somebody has to have my player, it's only a matter of time Wink
Indeed, i'm sure you'll have it recovered in no time. These players are very popular. May I suggest you to find a program called File Scavenger on the web and try to undelete the original firmware ?
  #89 (permalink)
Old 25th Mar 2008, 3:29 pm
Default pmp back up-need
hello to all
excuse me...
I need bcak up file for my pmp to upgrade that.
that is china sunplus::
spmp3050A
sd-ram
1gig
board license : pmp-704
i need original AIMG and BIMG and FW
when i push power main menu come up then after a few second will turn off
plzzzzzzzz help me... :cry:
  #90 (permalink)
Old 29th Mar 2008, 1:47 am
im also trying to upgrade mine.
my player is just like the one in:
http://www.dealextreme.com/details.dx/sku.9504
but has no time, calendar and no fm.
it has a blue background.
i tried firmwares that i found on the net but they didn't work as well.
can you guys help me?
