Ipod Nano 3rd Generation General Information
Old 16th Mar 2008, 9:47 am
Default Ipod Nano 3rd Generation General Information
Information I have found elsewhere on this mp3 player-
Manufacturer- Wilson Co. Ltd.
Bootflash Type- F285
BROM- 3.0.8
128x160 pixel screen
Information I have found on my own-
F/W version- 9.1.52
Serial #- BKSC91N215_32
Size-7x5.5x.75 cm
4 GB Memory (tested)
Color- Silver
USB 2.0 Connector
Built in Speaker
Built in Microphone
Buttons-
Top- Menu
Left- Reverse
Right- Forward
Bottom- Volume
Center- No label
Power Switch on Bottom
Screen Size- 4.5x3.25 cm
Screen Serial Number (Found Inside)- DFM-101C-NL-WD.GLbS101
Largest Chip Inside- Size-1.75x1 cm
Company- Hynix
KOR
HY27UT088G2M
TPCB
752A
9UJ2K620
Second Largest Chip- 1x1 cm
AK1025
7K044AB
OKH
Third Major Chip- small, raised slightly off of board
Comelent
CL601004
4607
Number on card, covered by another card
BKS25056_MV6A
NO:071116
The insignia near this number has a 'B' in the upper left quadrant, a right triangle with a bent hypotenuse with the right angle towards the center, the lower right quadrant has 'Kee', and the lower left quadrant has a mirror image of the upper right.
Old 16th Mar 2008, 9:49 am
Default Re: Ipod Nano 3rd Generation General Information
This is a brand new 3rd Generation (third gen) Ipod Nanolike styled MP3 video MP4 Player. Plays Music, Videos, FM Radio, and much more!
3rd Gen MP4 Player Manufacturer Specifications:
* 4GB Flash Memory
* Store approximately 1000 songs depending on song length
* Supports MP3, WMA, ASF, WAV & ACT Music Formats
* Supports JPEG image browse function
* Supports AMV Video Format - Convert MPG, MP4, MOV with software downloaded from our website.
* All kinds of acoustic equalizers: natural, rock, popular, classical, soft, jazz and DBB
* Multiple playing modes: normal, repeat one, folder, repeat folder, repeat all, random, intro.
* Timing shutdown: you may set the sleep mode and power saving mode, which will facilitate your application
Firmware upgrading function: the latest upgrading software can be downloaded on the Internet to accommodate the future expansion of this unit
* Full animation menu: the visual animation menus in combination of corresponding display of words make your application easier!
* Built-in FM Radio Tuner!
* Image Viewer (store and show your digital photos)!
* AMAZING 262,000 Color High-Definition color 2.0" TFT screen that can be viewed under any lighting conditions.
* Fast USB 2.0 Interface - Also USB 1.1/1.0 compatible)
* Plug and Play compatibility with Windows 98, 2000, ME, XP, Vista and MAC OS 9.2
* Re-chargeable Lithium-Ion battery through AC adapter (included)
* Doubles as a flash drive! Just hook up included USB cable to PC - store data files and songs!
* U-disc Function free of Drives: without management programs, you can directly operate files by means of “Moving Disc” un “My Computer”. You will not have to install any drive programs in WIN2000 or over.
* 4GB True capacity Samsung flash memory - not hacked/fake memory capacity like some sellers on eBay. Memory is true and as advertised or your money back!
Manufacturer Origin: China
Note: This is not an Apple product. This is the generic version - at less than half the price and with a lot more features!
http://etronicsland.com/silver-4gb-v...ign-p-245.html
Old 16th Mar 2008, 9:54 am
Update on the largest chip- it is the memory.
http://www.hynix.com/gl/index.jsp
Hynix is a memory company.
Old 16th Mar 2008, 10:06 am
Please list all info you can find on this MP3/4 player.
Also- If anyone know how to access/modify the firmware of the "ipod" with free software, please tell me/post it.
Thank You.
Old 16th Mar 2008, 10:41 am
!!!!!!!!!!!!!!ALERT!!!!!!!!!!!!!
This is a ordinary Chipod Clone. The video they use is made by me, they stole it from youtube. (should ask copyrights, hehehe)
I bought the clone from mp4nation and it was the normal actionchip mp4 player.
My Youtube username is vermaelenprojects and I have more demo videos from gadgets.
Old 16th Mar 2008, 3:24 pm
Alright, so now im on to F/W info of the Chipod.
Okay, i was ocd and bored, so i kept running extract.bat from s1fwx,
which supposedly doesnt work with v9 firmwares (whats the def of insanity anyways? doing something repeatedly and expecting a different result? huh....), but this time it did.
Here is the output-
---[ info ]----------------------------------
filename = 'dump.bin'
filetype = afi
md5 = 2E578222FCC2288667B2CF6AA20A0CEE
---[ info:afi ]------------------------------
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 9.1.52
dat = 00/00/0000
| BRECF285.BIN| | 16 kb | | F285 | | B | | AEC9BB68|
| SYSINFO.BIN | | 192bytes | | | | | | BD89C0C |
---[ info ]------------------------------------
filename= 'dump.bin.FWIMAGE.FW'
filetype = unknown
-end excerpt-
When I plug in my chipod, 2 drives appear- G and H.
I copy all of my music to G, and H isnt formatted.
My guess is that the chip is partitioned, and H is set up in a way that windows doesn't know how to deal with, and contaions the F/W and such. Can anyone confirm/disprove that? Also- does anyone know where to find the code for s1fwx.exe?
Also Also- Update on 2nd largest chip- i believe that it is the processor. As with anything i say, please confirm/disprove if you can- i have minimal knowledge of electronics.
Old 20th Mar 2008, 12:03 pm
Does anyone know wherei could find a decompiler for firmware files? I realize that it is unlikely that there is one, but please list any free decompilers that you know of- btw, I tried boomerang, and it crashed when i tried to decompile something. Also- does anyone know where to find the source code fo s1fwx stuff?
Old 20th Mar 2008, 12:05 pm
more than likely ANY source code you'd find of his'd be here
http://sourceforge.net/projects/s1mp3/
Old 23rd Mar 2008, 5:28 am
I found a program that can transfer music to a chipod with very little trouble- Mediamonkey
you can download it here-
http://www.mediamonkey.com/download.htm
Almost Dead Ipod Nano Clone 2nd Generation 4GB. Master1234 Dead Players 4 5th May 2008 6:02 pm
firmware for 3rd generation ipod nano clone(hacked 8gb = 1g) teron678 Dead Players 2 24th Feb 2008 11:04 pm
3rd generation iPod Nano clone dead mpxman Dead Players 3 30th Dec 2007 8:22 pm
3rd Generation iPod Nano, or Meizu pmilladcs General Discussion 11 24th Dec 2007 9:54 pm
