DVD to iPhone, iPod, Zune, PSP and other portable devices
Old 23rd Mar 2008, 5:13 am
Default DVD to iPhone, iPod, Zune, PSP and other portable devices
dvdXsoft DVD Ripper can rip your favourite DVD movies to VCD(MPEG1), SVCD(MPEG2), AVI(Divx,Xvid) and WMV formats. This DVD Ripper Software features high converting speed and excellent output video quality. Convert DVD to your favorite movies three steps as followed.
Step1: Load DVD Files
Open the "file" menu, and click "Open DVD" or "Open DVD Folder", then the DVD movie can be imported to the software. You can also directly press the "Open" button below the previem panel to load your movie.
Step2: Set parameters
Select the Output path, the default folder is: c:\dvdXsoftoutput. Set the output format:AVI(Divx,Xvid), WMV, VCD(MPEG1), SVCD(MPEG2). There are four Resoultions you can choose from: Keep Original, DVD NTSC(720*480), DVD PAL(720*576), User define(320*240) .
You can click "Options" button to set the Advanced settings, including: Condec, Video, Audio, Output.
Step3: Convert
After setting the parameters, only click "Convert" button, you can convert your favourite movies freely. The preview panel display the movie image when converting.
Done, so easy! Free try it!
DVD Ripper
ipod touch 16gb + iphone 8gb wil32 General Discussion 2 15th Dec 2007 9:13 am
Forget Chipods, I'm getting a 30GB Zune for $99 Brew Swillis General Discussion 33 22nd Oct 2007 6:23 pm
Are Hacked Devices Dangerous pmorony General Discussion 3 7th Oct 2007 12:33 pm
s1fwx saids "no devices found" sagitta Support and How To 6 9th Apr 2007 9:09 am
How Microsoft Zune and Sony's Mylo look like chipods razzer001 General Discussion 2 22nd Sep 2006 3:51 am
