Headphones won't fit in my player
just got an MP4 Touchscreen (before knowing about the forum) I tried fitting the headphones & they wont ! Are there different sizes of jack plugs? All my others are 3.5 but nothing i have will fit the hole.
This is the seller --> 4GB 2.8"LCD TOUCH SCREEN MP3 MP4 FM MEDIA PLAYER+GIFTS http://i21.ebayimg.com/06/i/000/e1/cc/4ad9_1_bl.JPG thanks |
Re: headphones
Some mp4 players have a 2.5mm headphone jack, you can get headphones of that size off ebay but they're not always great quality, hope this helps
malia |
Re: Headphones won't fit in my player
As maliagracemullally mentioned earlier, it seems your player has a 2.5mm hearphone jack.
You can get a 2.5mm to 3.5mm plug very cheap on eBay. Have a look here --> 2.5mm to 3.5mm Headphone Audio Jack Adapter on eBay. http://www.kc-kwan.com/online/pics/o...ddapter_01.jpg http://imgs.inkfrog.com/pix/honestyg...25to35line.jpg Hope that helps. |
From my experience, get the straight jack, not the one with the cord. All the corded ones I have play music at a lower level and are prone to shorts.
thanks for advice
| All times are GMT -7. The time now is 12:24 pm. |
