ONDA vx747 clone players ARE NOT ONDA but rockchip
Well as ever the chinese player market only succeds to confuse us.
There has been an explosion of the following devices appearing on ebay and a few shops at the moment http://img.tinydeal.com/mp3/ta5a.jpg Now, these players are a clone/copy of the original design from onda, see link below: http://www.onda.cn/pro/product/product.jsp?Id=12139 Now there is MAJOR difference in these players Onda VX747 uses Ingenics processor chip clone uses new rockchip RK2706 chip (as its cheaper) so basically apart from the way they look they are totally different players Use totally different firmware Are of lower quality Basically these clones have one purpose, to trick you into thinking you are buying an onda player!!! Also the specs on the sellers sites use specs for the onda player and these are WRONG so beware people, they may be cheap but you get what you pay for There will be NO UPDATES in firmware for the clone player Onda firmware WILL NO WORK on clone player some images to help with identification of fake vx747 using rockchip http://img.photobucket.com/albums/v4...ao/mp4/332.jpg http://img.photobucket.com/albums/v4...ao/mp4/322.jpg http://img.photobucket.com/albums/v4...ao/mp4/323.jpg http://img.photobucket.com/albums/v4...ao/mp4/325.jpg http://img.photobucket.com/albums/v4...ao/mp4/328.jpg |
firmware
Do you have the firmware the pictures in the bottom show or know where i can find it? Thanks
Re: ONDA vx747 clone players ARE NOT ONDA but rockchip
Cammarratta, I have player in bottom. if you want, i will upload it..
That would be great thanks putsarang.
http://www.megaupload.com/?d=T50GNKX3 <- firmware is here
if you want to install this firmware on your player, after install it touch 9th icon in main menu next the 4th is language setting, touch this menu and then set english. (cuz.. default language is Korean, sorry :oops: ) |
Not a problem and thanks for telling me how to get there thats a big help.
NO touch screen activity, and cannot detect battery and shuts down as ever proceed with caution, these players may look the same on the outside, but with so many knock off factories churning these things out we are getting player with no logic in their production BTW, on my screen i have some PRINTED icons that are on the screen itself, they are hidden slightly under the bezel to the right, do any of yours have this, they do nothing and i think are icons for another device (many phones from china have these screens) - just trying to make a point that these players are put together with whatever the factory can get their hands on at the time, and they will adjust the firmware accordingly to work with it, so this gives us a mass of players with so many variations, just to add to the poor unsuspecting publics confusion |
Yeah i noticed that on mine a while back. i really dont care that its modified. I want to know how they do it that way i can do it as well.
| All times are GMT -7. The time now is 9:38 am. |
