Does anybody know the difference bteen uxcell Omega V89 &
Old 16th Jul 2008, 1:16 pm
Default Does anybody know the difference bteen uxcell Omega V89 &
Hi guys! Does anybody know the difference between uxcell Omega V89 &''China 2GB MP4 Players Wholesale'' sold by chinavasion? In the pictures they look the same
Old 16th Jul 2008, 1:36 pm
i will say this
take with a pinch of salt any image you see reffering to shps sales items, often a generic image is used or even an image of the real player that their cheap version is selling
from the 2 you have mentioned and the prices i would say forget it - big time.
If you are looking for a cheap player, i would so far recommend this player from tinydeal, its based on the newer rockchip and has playFX sound (excellent) and much more flexible and more stable movie support. problem is with these is basically what you get is it, they are unnamed and unsupported from any manufacturer
http://www.tinydeal.com/index.php?ma...roducts_id=633
or
http://www.tinydeal.com/index.php?ma...roducts_id=541
If you want to take a look at better quality player with support and updates
www.mp4nation.net
These players are almost 2 years out of date in terms of technology, have low memory capacity and certainly are not of fantastic build quality compared to the players being produced today from well known Chinese manufacturers
in answe to your original question, they will probably be the same player, but like i said, be prepared for the player to look different on arrival (possibly)
Old 16th Jul 2008, 2:10 pm
Default Re: Does anybody know the difference bteen uxcell Omega V89
makd511 thank you for your reply and your advice. I arleady have a MEIZU M6 SL 4GB from MP4Nation but I am looking for something cheaper to give as gift to a friend
Anyway, those you have mentioned from tinydeal looks great
Old 16th Jul 2008, 3:25 pm
i would go with one of those from tinydeal, though i can not vouch for quality, ut they will be no worse than those omega ones
at least these ones at tinydeal use the new rockchip rk2706 which means better audio and better vide support, no more restrictions on mp2
good luck
BTW
meizu SL - got one myself, great player, i also truly reccomed you get the mDock, best thing i ever bought, use it every day - excellent
Old 17th Jul 2008, 10:40 am
looks nice...Can you charge the player while playing?
OMEGA V88 MP4 Opinions mpxguy General Discussion - Uxcell.com 8 31st Jan 2008 12:35 pm
anyone modded the firmware of their Omega V88 / V89 mp4? jsw-000 Mods and Themes 0 24th Dec 2007 12:32 am
Need help with my new OMEGA V88 mp4 player mpxguy Dead Players 20 28th Aug 2007 6:06 pm
ogg vorbis on uxcell's omega? kallek General Discussion - Uxcell.com 1 23rd Jul 2007 8:38 am
What's the difference between ver 35 and 37 firmware rakashmiri General Discussion 4 6th Jan 2007 3:16 am
