28th Jul 2008, 8:08 am
hard one - i want both, especially as Hacha will probably only release 4GB version, in which an SD card slot would be needed, but 3hrs quoted means less in real use so that is appalling life for battery
rather than developing 2 player work on a power management system instead
This is a shame, 2 thing that i have noticed form prospective buyer is that they want expandability and good battery life and i do not think the Hacha option is a good one at all
The only saving grace here is that you can run the player on external battery pack, but this is no real solution to me, just adds extra baggage when all you want is portability
sorry to be so negative, but there are solutions i am sure that can be made,
why is this BTW, are they trying to make the player too thin now to follow trend???, i would prefer an extra mm or 2 to accommodate an SD card reader and bigger battery
