What kind of chipt is this ?
Old 21st Aug 2008, 8:20 pm
Default Re: What kind of chipt is this ?
Originally Posted by David99";p=&quot View Post
Vidrop is one of the programs that I used. I agree that it works very well but I still had synchronization issues - for me it was converting a PAL .vob file to a XVID AVI. I still had synchronization issues, but just less. Even with a low bitrate like 300kbps and using 22fps frame rate. I could go 20 minutes without a synchronization problem and then it would happen.
This was when using two Rockchip 2608A based Ramos players. The Ramos sales rep admitted that they had issues with the Rockchip 2608A and would be only using the (then new) Rockchip 2706 in their future players. They even replaced the Rockchip 2608A used in the RM850 with a Rockchip 2706 in their reissued RM850+. Also, 22fps does not make for a very good viewing experience - the video gets jerky during periods of motion in the video.
What kind of settings did you use to get playback that would not lose sync?
Well... I don't know about this Ramos player... anyway in my Onda VX858 which is a rockchip with a screen of 2.8" of 262k colours I've mounted just musical clips... this is under 10 minutes of video.
I've used 320x240 22 FPS 500 kbps xvid... mp2: 44.1 khz 128 kbps... for this conversion I've used Xilisoft (not viDrop).
One important aspect is that videos can only run from flash memory when I've put videos in SD card video gets jerky.
Old 22nd Aug 2008, 1:58 am
Dear David99,
did you ever tried the "PAL Rockchip 320x240 high.ini"-Preset of the "50 new Presets for viDrop" ? You could find it under Downloads/Tools.
This Preset lower the -speed to 0.96 as an Extra Parameter for MEncoder.
Another way to solve this problem is the MEncoder option -delay. Read more about it in the manpages of MEncoder - viDrop is using MEncoder inside...
rgds, lca77
Old 22nd Aug 2008, 1:59 pm
Thanks for the tip lca77, I'll give that a try.
Old 22nd Aug 2008, 2:02 pm
DaremoS, that is interesting that the video gets jerky when running from the SD card. This probably has to do with read cycle times from the SD card and not the Rockchip or conversion. There are ultra fast speed SD cards that are very popular with the professional photographers. I don't know if they have the ultrafast SD Micro format though. worth a try I guess
What kind is this? Theredbaron Support and How To 0 1st Mar 2009 8:46 pm
What kind of player is this? fparri General Discussion 1 16th Feb 2008 12:29 pm
What kind of mp4 player is this? kinger Support and How To 13 4th Oct 2007 9:19 am
What kind of AMV file? Senna Video related 2 29th Apr 2007 8:02 am
what kind of fw? gil64 Support and How To 2 18th May 2006 12:42 am
