MC Tronics MP4 PLayer JR-696 (JREN)
Old 13th Sep 2008, 10:55 am
Default MC Tronics MP4 PLayer JR-696 (JREN)
Hi Guys!
I have downloaded the Program Chip Genius and the Programm identified the Chip as following:
Device Name: ++[E:][F:]+USB-Massenspeichergerät(RockChip USB MP3 USB Device)(RockChip USB SD...
PnP Device ID: VID = 071B PID = 3203
Serial Number: USBV1.00
Revision: 1.00/1.00
Device Type: Standard USB device - USB2.0 High-Speed
Chip Vendor: RockChip
Chip Part-Number: RK260X
Product Vendor: (N/A)
Product Model: MP3 Player
Tools on Web: (N/A)
From the JREN Homepage:
JR-696-Photo
Super slim fashionable design, metal shell, good soft feeling, Dimensional sound loudspeaker, double earphone jack
2.4inch Screen High clear TFT colorful display
Support AMV movie playing, Support various music formats of MP3,WMA
Support listening music when read E-book or playing games; Support SD card
Music-playing list function, use conveniently
Game-playing function
Built-in FM radio and recording function
Supper longer time about WAV recording, A-B repeating function
Support E-book (TXT), multiple bookmarks, support browse JPG format
Seven sound effects, multi cycle playing modes, Sound quality is outstanding, user-defined EQ
multi-languages menu, Synchronous lyrics display
Saving power design: light, backlight can be adjusted freely, user-defined turn-off time
High speed 2.0 interface, support firmware upgrade function
Rechargeable Li-Ion Battery
The Big question is are ther any other Firmwares outa there?
Are there some apps for example to read pdf files?
or for a better codec support?
I Hope you can help me!
Old 13th Sep 2008, 12:32 pm
Default Re: MC Tronics MP4 PLayer JR-696 (JREN)
Sorry to say there are no firmware upgrades for RK26xx Rockchip players unless the player is Branded like Onda, Teclast or RAmos and a few others.
Every firmware is matched to the players board and display so if you try to use a firmware from another RK26xx player you will 99% kill your screen lose and your existing working firmware with no chance to recover it.. :cry:
Old 13th Sep 2008, 12:44 pm
Hello ! And thanks for the Information!
Do you know where to get the rkp Files?
Are there only Games no Applications??
For example a pdf reader??
