Problem with my MP4 player rockhip based, SONO: CV6
Old 19th Oct 2008, 12:44 pm
Default Problem with my MP4 player rockhip based, SONO: CV6
Sorry for this direct question to you, but i am really disapointed from my mp4 player. it is rockchip and when i go to see its version it say onlu zeros (000.000.000...).everyting i put on it 60 % is becoming damaged. mp3 , pictures , movies ,... everything :cry:
i can't even see it with all aplication that i downloaded from your forum :S
so i cant do any upgrade or repair.plz help
1GB memory with SD card of max 2GB support.
262k TFT (220*176)
fm radio
Old 19th Oct 2008, 3:23 pm
damaged
either something is wrong with the files or your computer USB posrt may be wrong
one thing to try is to format the mp4 player memory
find the drive letter for the player and right click and select format option, format to fat 32 and see if this helps
Old 19th Oct 2008, 6:17 pm
Originally Posted by makd511";p=&quot View Post
damaged
i tried formating it , my usb ports are ok .i tried on every port on my pc :S the files are all ok. they are damaging randomly.
example:
same 10 songs , i putted them 4 times and everytime another gets cracked,
Old 21st Oct 2008, 4:55 am
so is there someone who can help me with this product?
Old 21st Oct 2008, 5:40 am
where did you get the music files from .. downloaded or ripped them yourself
maybe corrupted memory on the player
what happens on the player itself, does the player throw up error messages when selecting files
Old 23rd Oct 2008, 9:04 am
I rip the music my self and its 100% ok with the files.there are know error messages when selecting. the songs are playing and in some parts of the songs its getting trick there is some noise like error in the song and its continuing to play. same is for pictues some are 100 % good some are showed 70 % of the picture .
Same and for videos.
But i notice that isn't from the files cause sometimes the same song pic or video that is good when its in the player its getting the same problem when i put it in the player after format for example.
Old 23rd Oct 2008, 9:38 am
Default Re: Problem with my MP4 player rockhip based, SONO: CV6
You may have a dying NAND flash.
If you can/know someone that can solder, a new flash chip is cheap and relatively easy to replace. You *will* have to reflash the firmware though.
Otherwise, it's going to cost you more than the player is worth.
Old 23rd Oct 2008, 2:14 pm
yeah, it does sound like a memory fault to me also, kind of the end of its life im afraid, what happens when you play files and images from the sd card???
Old 23rd Oct 2008, 2:25 pm
I'd put my money on bad soldering on the memory chip.
Any chance of returning the player to the seller for exchange or refund?
Looking for Rockhip HS-3007 Firmware version 01.07.1075 prvteprts Firmware 0 1st Jun 2009 9:56 pm
Rockhip mp4 player update help needed chaoscreater Support and How To 26 3rd Feb 2008 5:36 pm
Help with a RockChip-based mp4 player jcberedo Support and How To 8 20th Nov 2007 6:30 am
Bad experience and Question about Rockhip player dadou23 General Discussion 7 30th May 2007 10:49 am
Rockhip firmware upgrade HOW? Edwin Dead Players 1 30th Jan 2007 7:38 pm
