>> output for headphones (jack) <<
Old 30th Oct 2008, 8:36 am
Default >> output for headphones (jack) <<
Hello ALL, I am from Russia, Sorry my English is bad((
So, i have problem with my MP4 (HACHA PC18)
So on my player broke down output for headphones. this does not sound as if by the end of the plug is inserted. He is physically inserted to the end. if to roll, pressed to plug in different directions, the sound appears ... but in this situation and it should fix that in your pocket to make not possible. leave of a millimeter lead to failure. Tried many headphones same garbage. What should I do? In the STS has already been done, and then again after 2 weeks some do not want garbage like that. I do not trust them ...
In reality, whether to replace himself and replace it? jack
Old 30th Oct 2008, 11:26 am
You could use some small tool to push metal things inside your headphones output in order to make them connect with the plug.
Perhaps the problem is that soldering places are bad.
Old 12th Nov 2008, 7:32 am
Take the board out, on the other side you will see the solder points of the headphone jack. Redo all soldering, letting each point cool down before you do another one for the best contact. If it doesn't work then either, get another jack and solder it in place of the old one.
MP5/PMP Sound output dewdude General Discussion 2 26th May 2009 5:50 am
Sound but no picture on TV output on MP5 player oilburner2 Support and How To 13 2nd Mar 2009 4:49 am
PLS HELP accidentally plug into subwoofer output jack darkzodiac Dead Players 0 15th Jun 2008 10:42 pm
Changing audio bps on output *.AMV files harry_pouter Video related 3 23rd Jan 2007 8:53 am
Headphones with 2.5 mm sub-mini jack Sciamano General Discussion 12 4th Jun 2006 3:01 pm
