How do I identify a player.
Hi all,
hope this is the right place to post this question. I have just received this player http://www.bestofferbuy.com/mp4-play...een-p-983.html and would like to identify it. It was a good price and arrived quickly. Plays well but there are a couple of issues I need to sort and think knowing the exact model would help. Thanks in advance. Everso |
hi and welcome
please see the following link http://www.mympxplayer.org/viewtopic.php?t=11069 i am afraid this applies toy your player and hat you have now is all it is ever going to be sorry makd511 |
Re: How do I identify a player.
Hi,
thanks for the reply. It is not so much that I wanted to update the firmware just that I thought knowing the exact type may help searching for solutions. The player mostly works fine and for $56 to get a 16Gb player I don't think you can be beat. Thank you for the quick identification. The 3 issues I have (in order of soultion wanted) are 1) I can not seem to convert a video to play on it - though the sample plays fine. 2) The txt reader will not auto scrooll - I like e-books and was hoping to use this feature. 3) The game (tetris) starts in paused mode and will not go no matter what I do. I think 2 and 3 may be related. Any light you can shed on these will be appreciated. In all honesty - if none of these are resolved I will still be more than happy with what I got and how much I paid. Once again - Thank you Everso. |
Update for those that follow. The power switch seems to function as a pause key ... go figure.
Ths solved problem 2 and 3. Now I just have to be able to gat a video on there without a "format error" when I try and play it and I am a happy camper. Everso |
You need to use viDrop to sort your video problems, download here:-
http://www.mympxplayer.org/tool-vidr...ter-df785.html see thread here:- http://www.mympxplayer.org/1-vt7071....r=asc&&start=0 |
Thanks. Only thing is the link seems to be to a diffferent £30 pice of software. Am I missing something here?
And I can't get a working file outof that either :(. |
I think you clicked on a sponsor link. :wink:
You need to click on the download button below that. :) |
Got it. Thank you everyone.
I now can do everything i ant with my little player without the need to flash it. I am one happy camper ... now, on to a cary case I think :). Everso |
| All times are GMT -7. The time now is 1:50 am. |
